As you know my layout Tara Jctn has been converted to DCC control over the last few weeks-and I'm definatly NOT going back....,
One thing that I cant seem to understand/set up properly is the Start Voltage,Top voltage,Acceleration,deceleration etc on my 201 locos,
An example;
Loco 220 and 221 go like a rocket when the control knob is only turned to (1) so I cant use these for shunting anything,however locos 201,202,210,229 have the right amount of speed-until you try and shunt coaches slowly into the valeting plant-they go a little too fast and cause the coaches to derail,
My 141 locos have the right settings and havent caused any problems,
Can anyone suggest/recommend what settings I should try on these locos in order to achieve slow speed shunting and fast running on the mainlines,
I'm also having trouble with the headlights not coming on in the direction of travel-and in some locos the cab lights dont work either.
I'm using the Gaugemaster Prodigy advance 2 as my controller,
ttc0169
Hi Lads,
An example;
Any help is much appreciated-Thanks lads.
8 answers to this question
