I've been fitting decoders to some of my Murphy 141/181s and decided to detail the front end of each loco by removing the coupling and adding the optional additional detailing.
How should the front skirt be fitted? Does it just push on, and do I need to cut away any of the NEM coupling socket which seems to protrude a little far forward?
Thanks in advance
Noel
PS: Thanks to whoever advised me a few weeks ago not to bother removing the walkway hand rails when prizing the body top off a 141/181, just disconnect the two cab ends. Saved me a lot of fiddling. Used two wooden ice cream sticks to squeeze the body sides at the lugs and then micro flat head to push body sides up 1mm.
Noel
Hi Guys.
Thanks in advance
Noel
Edited by Noel6 answers to this question
