Horsetan Posted October 22, 2014 Posted October 22, 2014 Am slightly mystified by the requirement to log-on twice - once for the Forums, and again to see my photo Albums. If I don't log into my photo Albums, the Forum prevents me from seeing my own photos that are part of my posts. Is there a way of adjusting Forum settings so that I only need to log-on once?
BosKonay Posted October 22, 2014 Posted October 22, 2014 You only should need to log in once for all site areas?
Horsetan Posted October 22, 2014 Author Posted October 22, 2014 You only should need to log in once for all site areas? That's what I thought, but I'm definitely having to log-on twice. That also makes me wonder: if I don't log into my photo albums, does that prevent everyone else seeing my photos?
BosKonay Posted October 22, 2014 Posted October 22, 2014 It might be you are logging in at http://www.irishrailwaymodeller.com - and the album is pushing to the site default, which is irishrailwaymodeller.com ? vBulletin might be considering both hosts as different...
Horsetan Posted October 22, 2014 Author Posted October 22, 2014 It might be you are logging in at http://www.irishrailwaymodeller.com ... I have always logged in at this address. Should I now change this to remove the "www" part of it?
BosKonay Posted October 22, 2014 Posted October 22, 2014 Give that a try see if it helps and I'll check on the backend.
Horsetan Posted October 22, 2014 Author Posted October 22, 2014 Give that a try see if it helps and I'll check on the backend. Thanks. Think that has fixed it now
BosKonay Posted October 23, 2014 Posted October 23, 2014 Ok cool, I'll check out how the site is handling that redirect!
heirflick Posted October 23, 2014 Posted October 23, 2014 Thanks. Think that has fixed it now ...that's 20 euro you owe to the Bos!
BosKonay Posted October 23, 2014 Posted October 23, 2014 I 'think' I've now sorted the server so that no matter if you try going to www. it will push you to the root domain, hopefully that's a permanent fix now, thanks for pointing it out horsetan
