If one is building up layers of plasticard to form complex compound curves what glue do folks use so that the joints cut easily, file and sand easily? I'm fairly ok on this with wooden model aircraft materials (e.g. balsa and lite ply), but I've only ever used polystyrene cement with plasticard before, or white PVA glue to stick plasticard to balsa structural beams on buildings. Many thanks. Also is there a plastic or similar filler glue folks use with plasticard?
Noel
Hi Folks
Noel
2 answers to this question
