WaYSidE Posted March 19, 2019 Posted March 19, 2019 Goods Wagon, no wheels, The wagon is on Nenagh rd just outside Birr, first field after last houses on bad bend, wagon on right as you leave town. Sorry i couldn't measure the wagon, was on private property and I on business driving past, so i hopped over the wall, took the photos quickly. looks like 50's 60's Cie goods wagon i wanna take it home! End to end joy above photo with vent, part rivited on this side upright on pressed steel angle iron, maybe its older than 1950's then its bolted on at the other end of wagon , opp' end see below and 3rd pic down, could been repaired earlier wagon didnt see any markings the frame door hinge detail, i love rust, no realy, i go to great lenghts to capture rust on all sorts of old items, see those nuts, me thinks there 1950's below is door on far side, by road with flashing, looked like alloy not lead, sorry was rushing, didnt think to check. below, as plywood was manufactured way back, no clues there, as too age ah sure what about another glorious view, smaller image than first pic, i noticed those boards on ground and theres some yellowish green paint... ye are licking the lips by now is that a Cie logo? doubt it, but as timber expanded so did paint, maybe a sellers mark, drips and all yummy. either great steel or not that old? i thought pins like this were 1930's not 1950's 2 1 Quote
popeye Posted March 20, 2019 Posted March 20, 2019 Very good, you must have used a whole roll of film on that. Quote
minister_for_hardship Posted March 20, 2019 Posted March 20, 2019 Bog standard CIE "H" van. Steel looks solid, could be restored with minimum difficulty. ( As a shed rather than a runner) Quote
WaYSidE Posted March 20, 2019 Author Posted March 20, 2019 16 hours ago, popeye said: Very good, you must have used a whole roll of film on that. Hi pop's ,, mutley is my fav', snigger , i no longer use rolls of film, plates my boy plates, had to resize the photos to upload to IRM, feels like waste of time now, 16 hours ago, minister_for_hardship said: Bog standard CIE "H" van. Steel looks solid, could be restored with minimum difficulty. ( As a shed rather than a runner) i was going to say with a bit of insulation it could be a dublin home!!! but i thought it better taste not to Quote
minister_for_hardship Posted March 20, 2019 Posted March 20, 2019 3 hours ago, WaYSidE said: i was going to say with a bit of insulation it could be a dublin home!!! but i thought it better taste not to Omit the insulation and then it would be a Dublin home. 1 Quote
