  • 1
Where to source small OO/HO wheels
One of my upcoming projects requires wheels that are ~6-8mm diameter.
I was wondering if anyone knew a source of wheels this size for 00/HO.
If not, anyone have experience putting Graham Farnish wheels onto OO gauge axles?
2 answers to this question
Markits produce 7 & 9mm blackened brass disc wheelsets and a 9mm spoked wheelset in OO.
The wheelsets are available in either plain or pin point axle for inside of outside bearing use.
The codes are:
MRJO7 Di/b---7mm disc inside bearing
MRJO7 Do/b---7mm disc outside bearing (26mm pin point)
Its probably best to phone Markits directly to check on availability, the website gives an update on the current situation
++44 1923 249711 10:00-16:00 M-F
markits@btinternet.com
http://www.markits.com/default.html
