Darius43
Everything posted by Darius43
  1. Holes cut in coach bodyside to enable flush glazing of new sides. Sides glued to coach body. Etched cab ends laminated to 1mm thick plasticard. Coach ends “thickened” at the roof joint to enable a rounded roof profile to be sanded. Sides and cab ends in place. Cheers Darius
  2. Question. It’s hard to find clear photos of the bogies of MPDs 63-65. Were they like first generation BR DMUs or similar to the earlier MPDs? Cheers Darius
  3. It’s MPD time!!! Construction commenced using a Dapol 60’ LMS coach as the base model. The, interior, glazing, wheels and couplings are discarded. The raised detail on the roof and coach sides is removed and sanded down. The moulded coach floor is removed apart from at the ends. Etched sides removed from the fret and offered up to the coach body. The etched sides are longer than a scale 60’ so I trimmed 3mm off each end to make them just shorter than the Dapol coach. This allows the ends to be sanded round. Cheers Darius
  4. Nets and reductor gear (from Isinglass Models) fitted and light chassis weathering to finish. Cheers Darius
  5. HMRS pressfix lining, lettering and numbers applied. I replaced the Hornby bogies with Bachmann LMS bogies. Cheers Darius
  6. Printing imperfections, which will need to be filled and sanded. Cheers Darius
  7. Painting completed. Original Hornby bogies temporarily re-fitted. Looks like it is sitting too high on the bogies - replacement Bachmann LMS bogies will be fitted. Cheers Darius
  8. I haven’t done any cleaning up yet - what you see is as supplied. There are some blemishes that need to be sanded down or filled and there are moulding lines on the roof to cab junction that need to be lightly sanded. Fortunately the CMAC resin is not too hard and is easily sanded smooth. Cheers Darius
  9. Received today - CMAC Models OO gauge 3D printed bodies, undergibbons and bogies for the NIR Class 450 DMU. I have applied a coat of grey primer to make the details more visible and cut down the bogie mounting bosses as the bodies sat too high on the bogies as supplied. Cheers Darius
  10. Chassis undergibbons added. Reductor gear door lights added using brass tube and clear LEDs. Cheers Darius
  11. Roof vents and other details added to coach ends. Primer coat applied. Cheers Darius
  12. Incorrect chassis undergibbons removed and big hole filled in. Coach ends blanked off with plasticard and offset gangways attached. Cheers Darius
  13. Doors cut out and replaced with plasticard versions. Cheers Darius
  14. Major refurbishment of the 1970s era Hornby LMS TPO coach into something less toy-like and more presentable. Coach disassembled. Only the chassis and body will be retained - the operating gear, coach ends and glazing will be discarded and the bogies will probably be replaced. Bodyside and roof moulded details carved away and sanded down. Cheers Darius
  15. Decals applied and light weathering airbrushed to chassis. Cheers Darius
  16. Work recommenced on the Gresley TPO - nets, reductor gear, glazing and lights added. Cheers Darius
  17. The Grob Tutor is a 1:48 scale resin kit produced some years ago by Heritage Aviation Models. They still have a website but it looks like it hasn’t been updated in a while… Cheers Darius
  18. I “repacked” the cabinet in the dining room having had the doors replaced and these were left over - there’s always some bits left over that you can’t get back in… Cheers Darius
  19. Back in 2002 I took part in a big defence trial at Woomera in South Australia. On a few days off a group of us travelled on the Pichi Richi Railway from Port Augusta to Quorn and back - including a trip on the “Coffee Pot”. When Ixion Models brought out an On30 version several years ago I couldn’t resist… The model is oob apart from my painting the roofs and adding “staining”to the carriage side timber panelling. Cheers Darius
  20. Hattons have recently been selling their O Gauge Gresley Pacifics at approx. half price. I purchased Union of South Africa partly because of the “bargain” price and partly because a friend and I rode behind her on the Bluebell a few years ago. The detail pack was supplied, minus coal load and fall plate so I made replacements. Really pleased although the 3ft length of O gauge track in the photos is all I possess do it’s going to be display cabinet material. Next task is to add the missing cab handrails. Cheers Darius
  21. Fantastic news. Orders placed for 3-car and 6-car units. Cheers Darius
  22. They are for the double cab MPDs - nos 63/64/65. Cheers Darius
  23. Personally commissioned etched sides and ends just arrived from Allen. Cheers Darius
  24. Yes it’s a shame what had happened to Michelin UK - both factories in Northern Ireland are gone now, Mallusk in 1982 and Ballymena more recently.
  25. Small world. Before we moved to Belfast in 1978, we lived in Newcastle-under-Lyme. Dad worked for Michelin in Stoke. Cheers Darius
