Hi, this is a slightly unusual issue I have, I know how to solve it, I just dont know whats causing it.
I have two Murphy Models 121's and of course I run them as a double header. Im usually diligent enough to dissolve the double hear before I turn the command station off. When I turn it on again, neither loco will move, individually or under the double header address.
If I then set up the double header, the locos will move together, I then dissolve the double header, each loco will move on its own address.
Then I turn off the command station and its deja vu all over again.
Other locos are not affected, its a hornby elite by the way.
Alan564017
3 answers to this question
