kevinclass201 Posted December 26, 2022 Posted December 26, 2022 (edited) Does anyone know the leanth of the platfomes at Enniscorthy station? Edited December 26, 2022 by kevinclass201
Past-Avenue Posted December 27, 2022 Posted December 27, 2022 Hi If you use Google maps you can measure the length of anything on it and would be very helpful .hope this is helpful as I use it quite a bit. Enda 4
jhb171achill Posted December 27, 2022 Posted December 27, 2022 Worth remembering too that the length will have changed over the years, so the length you want depends on the era you’re modelling.
hurricanemk1c Posted December 27, 2022 Posted December 27, 2022 Current usable lengths are 146m for both platforms. Note that'll exclude ramps, and sections of platform no longer used (if there are any, been a few years since I was down that way) 1 1
Niles Posted December 27, 2022 Posted December 27, 2022 3 hours ago, jhb171achill said: Worth remembering too that the length will have changed over the years, so the length you want depends on the era you’re modelling. Indeed, the 'main' platform was extended in March 2006, as seen in the snap below. The 'loop' platform was longer than the main to begin with. (Picture of a Strawberry Fair steam special in 2001 for comparison). 6
kevinclass201 Posted December 27, 2022 Author Posted December 27, 2022 8 hours ago, Past-Avenue said: Hi If you use Google maps you can measure the length of anything on it and would be very helpful .hope this is helpful as I use it quite a bit. Enda Thanks I did'nt know that Kevin
