Pete00018 Posted June 25, 2023 Posted June 25, 2023 Hi Could anyone advise where to pick up red/black bus wiring in Ireland. I've looked online unsuccessfully. I'd prefer to purchase at home then resorting to ordering from UK (also the shipping cost are equal to equipment in the order). Thanks Quote
0 Gabhal Luimnigh Posted June 25, 2023 Posted June 25, 2023 Any electrical wholesalers would gladly supply any type of blue, black, red, green cable and any gauge you require, where are you located? 1 Quote
0 Sean Posted June 25, 2023 Posted June 25, 2023 Literally just building a bus myself. im also just using off the shelf household stuff. https://dcc-ex.com/reference/hardware/wire-gauge.html https://dccwiki.com/Wire_Sizes_and_Spacing I found these two links pretty good for wire sizing info, if in doubt go for the larger size. Wires at my local shop were measured in mm2 and not awg so its handy to have the conversion table in your pocket when you get there. the feeder wires i sourced are awg and not shown in mm2 so again the table comes in handy. the larger gauge wire is essential on larger layouts where power will be travelling over a distance and there is potential for a voltage drop. if building a small layout such issues will not be as readily apparent and you may get away with a few sets of feeder wires. there is no correct answer you just have to build the thing to suit your needs. Happy modelling! 1 Quote
0 Pete00018 Posted September 3, 2023 Author Posted September 3, 2023 On 25/6/2023 at 3:07 PM, Gabhal Luimnigh said: Any electrical wholesalers would gladly supply any type of blue, black, red, green cable and any gauge you require, where are you located? Hi Gabhal, I am located in Dublin city centre. Quote
0 commerlad Posted September 4, 2023 Posted September 4, 2023 Find a Towbar centre. or car spares (Do you have HALFORDS etc) The cable is sold by the meter, and you get 7 colours (Including red and black.) just strip the outer. For thinner wires, A charity shop is the place to go, Old SCART cables have up to 20 cores and only cost a few pence each when stripped out. Quote
Pete00018
Hi
Thanks
4 answers to this question
