I've got one of Leslie's cattle wagon kits to build, and I need to make it for 21mm gauge. There must be someone on the forum who has done this already, please can you advise me?
Having done a couple of his 20' container flats, these were fairly easy to convert to broad gauge by removing 1mm of resin from the inside of the W-irons. But the cattle wagon W-irons are closer together and thinner, so that's not an option. Also it's not easy to cut the chassis unit down the middle and pack out by 2mm, because then it would be too wide to fit between the cosmetic solebars moulded into the sides. I think it would be difficult to remove 1mm from the outer edges of the chassis block without damaging the W iron and bearing detail.
I'm sure that a few weeks ago, when I bought the kit, I found an online video showing the build of these kits to 21mm, but I now can't find that anywhere.
I'm wondering whether the best solution is to just replace the floor with plasticard and use some etched W-irons. If so, is it possible to buy fold-up etched W-irons for 21mm gauge?
Another option might be to use a Parkside or Cambrian 10' wheelbase underframe, packed out 2mm, with the solebar detail removed from the donor underframe so that it fits between the cattle wagon sides. I could probably do that with bits I have in stock here - and might then be tempted to vac-brake it.
Mol_PMB
Any thoughts?
Cheers,
Mol
8 answers to this question
