spudfan Posted April 16 Posted April 16 (edited) Here is a few extracts from book which has a chapter on the creation of the Mont Cenis tunnel in the alps. The extracts here deal with the track and motive power. The book was written at the time of construction of the tunnel by someone who was doing some climbing in the area. Anyway I found it really interesting. If any one out there wants the whole relevant chapter I can email it to them. Edited April 16 by spudfan 1 2
Maitland Posted May 12 Posted May 12 The Fell system. It was trialled on the Cromford & High Peak line not all that far from me, and was meant to complete the Mont Cenis route while the tunnel was being built. Unfortunately for the promoters, the tunnel was completed using pneumatic drills much quicker than expected, the line was then obsolete, and they lost a lot of money. The centre rail was installed, for braking purposes only, on the Snaefell railway in the Isle of Man, and is still in use. Fell had other ideas for quickly built, lightly engineered railways, that never quite seemed to hit the target. The first two locos on the Pentewan Railway in Cornwall were to his design, and apart from having the cylinders above track level (!) were similar to those build for an experimental rapid- deployment "train set" military railway that didn't get adopted either. He had a very strange taste in locomotive design, even for that age. If you can be bothered scanning, I'd love a copy. 1
Mayner Posted May 13 Posted May 13 The Fell centre-rail system was used on a number of lines in New Zealand the most famous application on the Rimutaka Incline opened in 1871 remained steam worked until replaced by a tunnel in 1955. https://www.rimutaka-incline-railway.org.nz/history/fell-centre-rail-system. The Incline with its 1:15 gradient was on the then main line from the capital Wellington to the interior, from the late 1880s trains were worked by multiple Fell locos spaced through the train. The Fell system was used into the 1960s for braking on two steeply graded coal branches in the South Island.
