Is she or isnt she?
Hi Heirflick, Those are hand operated points and in some circumstances they can be trailed through by locomotives etc without causing any damage,they are not connected to any CTC or signalling system,but are normally operated by the shunter.
If you watch a loco run round at Inch Abbey on the DCDR you will see a spring-loaded point in action - it is set for the passing loop and the loco goes through it from the platform road.
does it return to its origional position once the train passes?
