Bought a sound decoder yesterday and it arrived this morning (thanks Gareth and all at ModelShopBelfast ) but now have more questions :
1. I had heard before that there was an issue with the standard speaker on the 201 (only really for the horn) but looking for advice on how easy it is to swap this out for a better speaker. I havent looked in detail but I'm guessing the whole body needs to come off as no easy access to the speaker as with the decoder.
2. My Hornby Select has finally started to show its limitations. Apart from turning on the normal running lights I appear to have lost all control over the main headlights and the cab lights I'm guessing you need a controller which can control more than 9 functions as apart from F0 (lights) everything else is a sound function. If anyone has the full list of functions for these sound decoders it would also help.
Only got to run it literally for 5 mins but sounds great other than the horn which appears a bit distorted, will get to play a bit more this evening hopefully.
aramand
Hi,
Thanks,
Declan.
50 answers to this question
