UP6936 Posted January 13, 2014 Posted January 13, 2014 Hi all, Recently one of my class 50s failed, and since it was my favourite, the other one, which had a better chassis but worse body shell donated it's chassis to the failed loco. Now I have a shell and chassis spare, however the lima motor is utterly dead, and im wondering if it is feasible to refurbish it with a central can motor based drive system built on the original frame? I would quite like to try this as im looking for a project to focus on, and I have a soft spot for lima.
Warbonnet Posted January 13, 2014 Posted January 13, 2014 You could buy spares from a Hornby 50 and transplant them into the Lima 50 underframe (including bogie spares) if you want a central can set up. This might prove a useful guide (okay it's a 31, but the concept would be the same. http://www.rmweb.co.uk/community/index.php?/topic/19369-brush-type-2-re-birth-judgement-day/ Alternatively the units we discussed recently would work in a Lima 50. What's gone wrong with it? Is it the motor itself? Did you clean the wheels and pick-ups? Are the gears damaged? Loose wires/connection? http://irishrailwaymodeller.com/showthread.php/2800-Cost-effective-remotor-options-for-the-Lima-201?highlight=lima
UP6936 Posted January 13, 2014 Author Posted January 13, 2014 I believe the motor itself is just done. I will keep my eye out for hornby spares, as well as those units you mentioned that had come up in discussion. Thanks for the link, it will definitely be useful
Warbonnet Posted January 13, 2014 Posted January 13, 2014 I believe the motor itself is just done. I will keep my eye out for hornby spares, as well as those units you mentioned that had come up in discussion. Thanks for the link, it will definitely be useful No problem mate. If you were ever in Dublin you could drop it into Marks Models on Hawkins st and Jim would have a look at it for you.
BosKonay Posted January 13, 2014 Posted January 13, 2014 You can sometimes find lima motors on ebay for a few quid too...
UP6936 Posted January 13, 2014 Author Posted January 13, 2014 Thanks guys. Warbonnet, im actually going to be in Dublin Saturday but Im only down for the afternoon so might not be able to go to marks. Boskonay, I will keep an eye on eBay.
