Geordiekerryman Posted February 9, 2014 Posted February 9, 2014 Bikers End has developed into two baseboards. Of course these baseboards need Locating dowels for accuracy in assembly. The only retailer I could find them on Ebay won't post to Ireland the English B*****. Does anyone know where I can get them Regards Geordiekerryman
UP6936 Posted February 9, 2014 Posted February 9, 2014 You could buy dowling rod in B&Q and cut them to size yourself. Might be cheaper too
mrhd Posted February 9, 2014 Posted February 9, 2014 If the ebay seller will post them to N.I. then you could try using parcel motel http://www.parcelmotel.com
Shinkansen Posted February 9, 2014 Posted February 9, 2014 Have a look at http://www.stationroadbaseboards.co.uk/. They can supply 'bullet' type and 'pattern makers' type baseboard dowels. They deliver to Ireland and I have bought from them previously. Picked up some of the former for my own layout. Was intending to use these to join the boards end to end but have decided against it. Will use them instead for locating the hinged access section on the layout. If you're planning on dis-assemblying and re-assembling your layout on a regular basis, or if it's of 'modular' construction, than dowels are a good idea. But if it is going to be largly static, I wouldnt bother. Better off clamping your underframes together, ensuring the top surfaces are level. Then drill and fasten the base frames together with M10 bolts with flat washers and Nyloc nuts. They won't go anywhere and can be taken apart in future if needs be. Tom
WRENNEIRE Posted February 9, 2014 Posted February 9, 2014 Check out Baseboard Dave from this parish I am sure he can sort out some for you He uses metal type male & female yokes on his boards
Dave Posted February 9, 2014 Posted February 9, 2014 If your layout is permanent I do what Shinkansen said, clamp them together and drill and bolt, they will never move. Stay away from the pattern maker dowels it is very hard to align them perfectly. I now use hardwood dowels and drill the frames with a boring machine, that gives me perfect alignment every time. My old exhibition baseboard had them and they never wore down after a year and a half of constant use. If your planning to take it apart the odd time, clamp the frame then drill 8mm holes and fit hardwood dowels, then drill and bolt them together.
Geordiekerryman Posted February 11, 2014 Author Posted February 11, 2014 They are the people I was referring to
