New Servo Motor Point Control System
I have become an authorised dealer for Megapoints controllers. The Megapoints control board can control up to 12 servos and can be linked to a DCC module that can control up to 192 points!
This is a very reliable way of switching points, if the servo fails than it's a cheap replacement without having to replace the main control unit.
It is very easy to program and set up.
The controller can also be used on semaphores with a very realistic bounce.
I will be offering a complete package tailored to your layout, including the controller, servos, mounting brackets, linkages, power supply, switches and LED indicators.
Prices are as follows.
Megapoints controller €70
DCC Module €35
Servo motors, including mounting bracket and linkage €6 each
Switch €2.00 each
Pre wired LED €2.00 each
Micro switch with mounting bracket €4.00 (For frog polarity switching)
A basic per point cost €11.83 without switches or LED's is great value for money.
I will have it this coming Sunday at Bray, then Cork.
[video=youtube;NIN-ztKiAoY]
