I was watching some you tube video of claremorris workings pre 2000 , including foynes ballina coal train and also manuala shuttle ( 071 and two coaches ! )
Couple of questions for knowledgable types.
The locos ( 121 pAir. ) seemed to detach from the foynes coal train at claremorris , and ( videos ends) either to run round or return light engine ( to where ? ) , since the train is going to ballina , can't see the purpose of the run round. Any ideas ( the train stopped at platform 3 )
In the shuttle video. It's clear the 071 is running round the shuttle to return. Interesting the engine is given starter signal , rather then the shunt disc, which I find strange , as this would to my understanding , require a blocking back into section , and line clear request etc. the crossover was hardly outside the claremorris limit of shunt. Of was cie casual about this sort of thing , normally starters can only be pulled off of the line ahead is clear and all signals are off into the next block ( or the train was accepted under limited acceptance rules )
Interesting the limit of shunt signals are clearly delineated at the western side of the station on the signal diagram. But not so on the eastern side ( dub, limerick etc ) funny ?
Any views ideas etc
How long did the coal trains run, they seemed to be containerised rather then hopper is that the case ?
Junctionmad
Any views ideas etc
Thanks again.
Edited by Junctionmad20 answers to this question
