Cobalt Point Motors: Can I ask you now that you've had cobalt point pointers installed for over three years what you now think of them? (i.e. reliability, robustness over time, etc). A few questions if you have the time:
Do Peco points need to be adapted in anyway (i.e. remove center spring)?
I know very little about them, but if they only need two wires to the DCC backbone, can they still be operated by analog lever switches rather than just accessory numbers from a DCC cab?
The cobalt lever switches with the safety release look a bit large and unwieldy as well as expensive, which type of lever switch would you now recommend?
What motor model do you recommend? Currently I have insulfrog points which seem to be fine with all wheel pickup diesels, but in the future I suspect I may replace some points with electrofrog. Therefore would you recommend a model that could do for insulfrog now (i.e. ignore circuit switching), but do electrofrog switching in the future?
How did you fig them to the baseboard? Did the double sided tape to ply stand the test of time or did you have to glue, or screw them?
Will they work for some points where they cannot be located directly under the points (i.e. via horizontal push rods for points sited at baseboard joints)?
The new version is self-centred and handles the voltage issues better.
On the Peco point adaptations, yes, I use electrofrogs, which need a few 'tweaks'.
Here is how I do mine:
On the motors themselves, check the documentation (which is excellent) on the link above. It details how they wire up, how to control them, how to build a control panel with levels or buttons/leds and how to use them in an offset or in pairs for crossings.
I fitted all mine using the available foam pads, not a bother in 3 years and counting...
BosKonay
Breaking this out from Amiens Street, from Noel
I'm still a fan, to start with
Since installation back here: http://irishrailwaymodeller.com/showthread.php/4-Amiens-Street-Terminus?p=14759&viewfull=1#post14759
They've not given a moments trouble, bar some initial voltage issues which made them problematic to programme. Since then, DCC Concepts have 'updated' the motor, and branded it http://www.dccconcepts.com/catalogue/a/Point-Motors-Cobalt-iP-Digital
3 answers to this question
