Sails Posted December 7, 2018 Posted December 7, 2018 All, I mentioned in another MK2 thread a while back about a missing wheel set from one of my new MK2 coaches, the diner coach. I had sent a message to the retailer inquiring about a replacement set (I would have settled for a part number I could source myself), but unfortunately the retailer did not respond. Now that I have the coaches back after weathering I can see what I need as a replacement. SO far the closest I can find as a match is this part from Bachmann. https://railsofsheffield.com/products/5283/bachmann-36-033-oo-gauge-turned-coach-wheels-x10-for-non-close-coupling-bogies- I don't think its an exact match but after a bit of dirt application and when its under the bogie you'd have to be a damn good eagle eye's wheel nerd to spot the difference. Any thoughts an another wheel set that may be a better match? Mark Quote
Glenderg Posted December 7, 2018 Posted December 7, 2018 Can you measure the tyre diameter - the bit part that hits the railhead? Quote
Brendan8056 Posted December 9, 2018 Posted December 9, 2018 The Bachmann ones you mention are probably about 14mm size, whilst the B4/B5 bogies have smaller diameter wheels, nearer to 12 mm. Just to make it even more difficult Murphy's coach bogies that I have use an axle length of 24.5 (which is the standard HO European length) rather than the usual British 00 length of 26mm., so the Bachmann axles will be too long for the bogie. Gibson will do wheels at 24.5 axle length (this was used by Lima in their 00 coaches) so I would suggest you try that manufacturer. Hope that helps, Brendan 1 Quote
Dhu Varren Posted December 9, 2018 Posted December 9, 2018 You could try these wheels. I have used them on MM Cravens coaches. https://www.petersspares.com/hornby-h51-replacement-wheel-set-for-lima-ooho-coach-stock-x9695.ir Quote
Sails Posted December 9, 2018 Author Posted December 9, 2018 Thanks all, the wheel diameter is 12mm (11.2ish traction inner ) and the axle length is 24.5mm. The wheels mentioned on Peters Spares look the part but he's out of stock. I must ave had a bad QC batch from these coaches, one wheel set missing and on another coach the wheel set was not inserted correctly into the bogie. Mark Quote
DB JOE Posted December 9, 2018 Posted December 9, 2018 HI Sails Peters Spares has those wheel sets. They're under the product code as PS34. Quote
