Darius43
Everything posted by Darius43
  1. Hot wire cutter used to sculpt the polystyrene. Then we get plastered. The slope at the right hand end is too steep so I’ll re-profile it later. Re-profiled. Cheers Darius
  2. Scenic element made from expanded polystyrene packaging and card stock for the roadway. I’ll let the glue set overnight and then sculpt it with a hot wire cutter. Cheers Darius
  3. No busses on this bridge… Dump trucks are repainted Oxford Diecast. Cheers Darius
  4. Bridge painted and weathered. Cheers Darius
  5. Quarry road bridge constructed using hardboard, plywood offcuts and card stock. Cheers Darius
  6. Come on IRM - where are those Jeeps? Cheers Darius
  7. Water tank made from card and plasticard. Cheers Darius
  8. CAF 3000 unit now running. The unit was made using CMAC 3D printed body shells on modified Bachmann Class 170 chassis. Cheers Darius
  9. Spoil loading bank painted and weathered. Cheers Darius
  10. Spoil loading dock constructed using 2mm card stock. The dock structure has now been coated with diluted pva prior to painting. Cheers Darius
  11. MED now running nicely. Added pickups to the trailing bogie of the power car to improve things. Cheers Darius
  12. Modified another OD Land Rover. Cheers Darius
  13. Modified Oxford Diecast Land Rover using thin plasticard. Still need to add outer mesh screen to windscreen and touch in head and tail lamps - plus number plates. Cheers Darius
  14. Some 1960s NIR stock on the move. Cheers Darius
  15. UTA trains in action. A Larne boat train and post war Railcars 6 and 7. Cheers Darius
  16. And the 80 Class is now operational. Cheers Darius
  17. Dusted down the 70 Class for a run. I added pick ups to the trailing bogie of the power car to prevent gapping at the insulated frogs. Cheers Darius
  18. My first and only main line steam trip in Ireland was from York Road to Whitehead and back in 1978, hauled by one of those two locos - not sure which but I recall it was green. Cheers Darius
  19. Power bus installed below the baseboards with feeds to each length of flexitrack soldered to the undersides of the rails. Found one short due to one of the turnout frog rails not having an insulated joiner - fixed. Running fine on DCC. Cheers Darius
  20. Planning to use the same technique to build the station buildings and canopy for “Whiterock”. Cheers Darius
  21. Hi Leslie, I used 2mm and 1mm thick card stock for the main structure and roof along with thinner card (photo print paper). For the cabin glazing I used clear acetate sheet (Ratio kit packaging). I used Ratio windows to make the large glazed units to the frame room. Cheers Darius
  22. First running Cheers Darius
  23. It’s a duck under access scenario. Power bus installation tomorrow. Cheers Darius
  24. Double track circuit completed. o Cheers Darius
  25. This popped up on my YouTube feed - nome nice UTA railcard footage at the start. Cheers Darius
