BosKonay
Moderators
Everything posted by BosKonay
  1. Can you tell us more about the machine Glenderg? Is it a computer cutter jobbie? I've seen some examples on rmweb of similar output and it looks like an amazing way to get perfect 'copies' and rapidly prototype / build!
  2. Hear hear Finer gent you won't meet !
  3. Absolute Gent Rich - drop me a PM with how much you want for it!!
  4. So where the orange wire and ipad are, will be mainline, which then sweeps off to the right in the distance.
  5. The orange ducting is just .2mm orange multi-strand electrical wire It looks about right in terms of colour, but might be a little small... have to experiment with getting it to sit in straight lines
  6. There is a left point leading to the shed, then a junction / crossing where the mainline meets the throat. The mainline then sweeps off on a large curve to the right around the corner
  7. Cheers Richie, Coming along slowly more like! The clean up, stock sort, attic clear, shed clear and other DIY have eaten all the time Need to finish the wiring, lay the shed, install the mainline and the boards for the right hand side and loop are going in Thursday!
  8. Obviously the cable trunking is a 'mock up' ! Not that the perway team aren't half sozzled half the time
  9. 2 weeks ago the last update says to me in an accusing tone!! To prove I've not been slacking, I took a few snaps First off, the storage / stock boxes have been moved in to the attic / storage area, which of course had to be cleaned out first. But the right hand loop is now clear and ready for baseboards as a result! In other news, the station throat and point work has been getting a little detailing, in the form of some trunking, orange ducting, etc, and point motors, a little ballasting has been done, the back platform is glued in place and I've modified slightly the shed that was facing the platforms into an open air fueling and service area for DMUs. Otherwise I'm still waiting for a box of Neodymium magnets (on a slow boat from china!) so I can install all the uncouplers I need, before I can finish the ballasting and hard standing! Here is a flavour of where things are at now.
  10. Here is a Google Map to the location http://maps.google.ie/maps/ms?msid=217648884781292518535.0004b54ecbaac74441021&msa=0&ll=53.373498,-6.194594&spn=0.007566,0.01929
  11. Ballasting looking amazing!! Just the right colour and texture!!
  12. They are the kind of buildings that inspire you to create a layout to the highest possible level, just to not look out of place alongside them!
  13. Gobsmackingly beautiful as always Glenderg!!
  14. Damn that's pretty :)
  15. Looks good!@ Which Ballast are you using? It looks very well!
  16. http://www.scalescenes.com/products/T032-Gantry-Crane
  17. And Walthers http://www.kato-unitrack.co.uk/walthers-cornerstone-933-3109-kalmar-container-crane-kit-22606-0.html
  18. Also Lima version http://www.ontracks.co.uk/index.php?page=product&prodID=82512&catID=654
  19. http://www.gaugemaster.com/item_details.asp?code=KI11752 is one option
  20. 50 minutes well spent
  21. You can also buy them in small self-adhesive strips with resistors, etc prefitted. Ebay search for SMD LED Strips. They can have droppes soldered to them, and then stuck to the underside of building roofs, fuel points, you name it. They are very flush , so work well!
