Everything posted by Noel
Yes its fabulous. I can almost here the echo of the motor cycle coming up the road from the Rugby club, interspersed with occasional waves crashing on the beech bathed in moonlight under the clear cold cosmic sky, with billions of galaxies visible to the naked eye. Wonder if they have trains on any of their planets . . . the horn of a distant 141 interrupts as distant rail noise heralds the imminent arrival of the mail train from Rosslare.
GSV slowly but surely nearing completion. Awaiting decals, a few bits of detailing and weathering, but should be finished early next week. Keen systems LMS suspended sprung gangways added, replica B5 bogies and somebodies sprung buffers I can't even remember! The last item I have to source is a model of Noel Enright waving out the window
Hi Richie. This is fascinating. Thanks, as I said I'm purely using guesswork as to the precise thickness of the older CIE roof level stripe based on visual observation. I've done my best to scale these to similar pics the same at the coach ends despite the slight difference in perspective. The older CIE livery GSV on RHS does seem to have a thicker white line than the newer GSV in IR/IR tippex on LHS, but not as thick as the 6" used in the 60s and 70s B&T Craven and Laminates. JB may have some additional nuggets of specifics. I'll leave it up to you two to advise. Now if you had some Kryptonite and a few spare Dilithium crystals to put in that flux-capacitor you might be able to travel back in time to 1974 with a calliper and measure fact from "turf burner" myth so I could get on and finish this model. Photos (C) Stephen Rabone (http://steverabone.com/RailwayPhotographs/ireland_1984.htm) Note the GSV stripe not as thick as the Craven behind but as JB states the lower edge lines up with the lower edge of the Craven. CIE era Park Royals and Craven with 6" stripes as opposed to the later IR/IE era 3" tippex
Thanks Jonathan. Dirt it is then
Thanks Richie. Useful info, too, especially the 'flux capacitors' effect on roof peeling Re the thiner white stripe, I just noticed the difference from photographs and approx eyeball measured from pics, but Jonathan's (the Oracle) explanation seems spot on. I'm taking a little poetic license on the roof colour because I can't find any 1970s delivery pics when they were presumably initially BR mk1 grey and I just don't like pure black roofs on the layout. I don't know how soon CIE would have painted the roofs black after delivery, or if they just did the sides. When I do the B&T GSV after next, it will be tippex era, so that will get the fifty black 'flux capacitor' peeling roof treatment. The next will hopefully be RPSI 3173 BCK in Maroon using a Bachmann donor instead of Lima.
Is there a model of you Noel on Shapeways in 4mm scale?
This is the look I'm after in the CIE early 1970s livery (Rosslare) even though the GSV below is BCK layout, my model is BSK. Photo (C) Stephen Rabone of 3174 taken 1984 (cleanish GSV) from his site: http://steverabone.com/RailwayPhotographs/ireland_1984.htm
That's really helpful Jonathan, thanks for the info. I do plan to weather the sides. The paint is still drying.
Back to GSV for some spray painting. Tan and White bands approx painted before reverse masking. Roof light grey as I was going to use maskol to create light grey peeling blotches under black roof but decided against filthy black roof as these were not in that state in early 70s when delivered. Reverse masked the white band and tan bands. I meant to make the white and orange edges in the black zone fuzzier so there wouldn't be a ridge but I had a 1/2" ridge of masking tape between the white and orange zones while I was spraying so I could do both in one go without overspray, but left a slight ridge at the edge of the temporary white band which would end up narrower after the reverse masking. After this I sprayed black all over, and then a dusting of frame dirt on the chassis, bogies, ends, and gangways. Relieved when I pulled the masking tape off to reveal the white band and the tan band. The white band (4.5") during CIE Black'n'tan era was not as wide as on the laminates, cravens, etc (6"). As this GSV is done in early 70s CIE livery I decided to do the roof in the earlier grey colour lightly weathered. It wasn't until the IR/IE era that the roofs were in an awful state with black peeling off to reveal the earlier grey underneath. Next up add the gangways, bogies, light weathering, then gloss varnish, decals, matt varnish and add the door grab rails, water fillers, etc. I'm enjoying this but it's taking forever. Can't help wondering of it would have been easier to buy an RTR one and modify it!
Thanks Jonathan. Somewhat inspired by "Rails Through the West". Did you notice the slight coach wobble I've accidentally introduced to the Laminate due to thinning the chassis bogie mounting plate. Same problem as the RPSI cravens. Will need to add a washer shim inside the chassis to tighten up the bogie pivots.
Thats a good idea. This is the LED I'm using for tail lamps http://ie.farnell.com/kingbright/l-2060hd/led-1-8mm-red/dp/1142456 Its the same one sold by Train-tech as a tail lamp.
I've been trying to figure out the simplest and most cost effective solution for coach lighting and tail lamps for brake vans, coaches, etc. I've looked at some of Train-Tech's battery offerings and others, but decided to experiment by trying to 'grow' my own. Experiment no 1 - Tail Lamp - Runs off track DCC, no decoder required, flicker free. Same circuit would do for coach lighting. On all the time. It's about 1978 since I last used a bread board, but I have to say its fun going back. Components used in test 3v Red LED (or LED lighting strip for coach interior) Bridge rectifier (converts 16v pulsed DCC/AC to 12v DC) - 50v rated 1k Resistor to drop voltage to approx 3v suitable for LEDs 1k Trimmer resistor to adjust light level 1000uF capacitor - avoids flicker if wheel pickup interrupted while running (e.g. over points, etc) - 25v rated The little Red LED that I have sourced is almost the same shape as a tail lamp with a flat bottom, curved top and 1.8m lens so I will paint it white except for the 'lens' and it might pass as a tail lamp. . . . more to follow when I fit it to a brake van and test run on track, then a coach. Have to decide wither I will use axle spring pickups or phosphor bronze strips to wheel backs for electrical pickup. PS: I ordered these parts only last night from Farnell and Radionics and to my astonishment both were delivered this morning!!!
Interesting look back on Irish Railways
Noel replied to burnthebox's topic in Photos & Videos of the Prototype
Video Clip. CIE local branch train early 1970s. Dutch heating van (SF), CIE Laminate (ex-Hornby LMS Stanier) and Bulleid luggage van (IFM).
Running trials for the pseudo CIE Laminate (Hornby Stanier) respray I did last spring behind B121. Ride height is a little high. Have already remounted bogies closer to chassis, will have to take another 1.5mm off the ride height. B121 (3D + Athern chassis) hauls local train A nice little local passenger train. Dutch heating van, Laminate and Bulleid luggage van.
Cork train 1979 http://euscreen.eu/item.html?id=EUS_47DAF4AEC39D4F42B3B87978122B406A Well its video of an Irish train and a train station. How far we have come as a country since this train in 1971. http://euscreen.eu/item.html?id=EUS_50208AD978A54A2790305D71849B6EF0 -
Thanks Paul for posting that little nugget. -
It looks like a giant storage heater on rails
Noel, that scene looks super. Yummie. Concrete yard finish looks spot on. the other Noel
Any rough idea when you might be able to ship orange Bubbles to customers? (i.e. is there a possibility they could ship this side of Christmas).
Careful now, Down with this Sort of Thing 201 is the class leader - worth waiting for
Thanks Dave. You're a treasure trove.
Does anybody have a spare copy of this to sell? As featured in Dave's Lima Murphy Models thread?
shunting freight HELP DESIGNING A SMALL SHUNTING MODULE
Noel replied to pauldelany's topic in Irish Model Layouts
Photo Gort Railway Station (C) Barry Carse Fab 1970s photo of Gort with loose couples 2 axle goods traffic active in sidings with B181
