New Layout for a member of the MRSI
Just completed this layout for a member of the model railway society of Ireland.
Scenery is next on the list, its an all Irish layout.
Superb build,great idea with the raised station.Good use of the space available,my own layout has about the same space available and it can be surprising what can be fitted into a limited space with a bit of planning.Well done,great workmanship all round.
Cheers! As the layout is only 10 feet long there was not enough room for a proper station.
Can you give some more info on how you made the control panel, Material, switches, wiring, leds etc.
I need to make a few for my layout.
Cheers,
Wiggy.
Hi Wiggy, I made the schematic from sections of the layout in Anyrail, I copied the sections in Anyrail to a new drawing. Printed it out on A4 and then glued t to 6mm MDF then covered it with clear contact adhesive.
The switches I got on Ebay,
http://www.ebay.ie/itm/Hornby-Peco-Alternative-Points-Switch-10Pack-SW301b-/160496061737?pt=UK_Trains_Railway_Models&hash=item255e4f8d29
I used bi-colour 3mm LED's red/green.
http://www.ebay.ie/itm/5-x-Bi-Colour-LED-3mm-Red-Green-UK-1st-Class-Postage-/121121721694?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item1c336acd5e
You will need bezels and a 1k resistor.
I used the Peco PL-15 twin micro switch, one for switching the polarity on the electrofrog and the other to switch the LED's on the mimic panel, I also fitted some signals to the platform level, they also switch with the points.
Here's a couple of pics of the mimic panel
[ATTACH=CONFIG]8884[/ATTACH][ATTACH=CONFIG]8885[/ATTACH][ATTACH=CONFIG]8886[/ATTACH]
Thanks Dave,
Gives me something to do over the winter.
Wiggy.
