burnthebox Posted July 8, 2014 Posted July 8, 2014 Hi all, anyone on here know how to dismantle carriages, are the any video's showing such "craftsmanship" or is it just trial & error, I have a Lima MK1 ready for destruction,
0 jhb171achill Posted July 8, 2014 Posted July 8, 2014 Probably depends what parts you want to re-use....?
0 burnthebox Posted July 8, 2014 Author Posted July 8, 2014 Probably depends what parts you want to re-use....? Hi & thanks jnb, I would like to reassemble the whole thing, having maybe cleaned & repainted it,
0 ak425 Posted July 8, 2014 Posted July 8, 2014 Hi all, anyone on here know how to dismantle carriages, are the any video's showing such "craftsmanship" or is it just trial & error, I have a Lima MK1 ready for destruction, There are plenty of recent pics ( and probably videos ) of the Mark 3s having a bit ' of work' done on them. I cannot help you thankfully as I only have photos of them doing what they were meant to do - Carry Passengers !
0 burnthebox Posted July 8, 2014 Author Posted July 8, 2014 There are plenty of recent pics ( and probably videos ) of the Mark 3s having a bit ' of work' done on them. I cannot help you thankfully as I only have photos of them doing what they were meant to do - Carry Passengers ! So where are the pics and the vids
0 Glenderg Posted July 8, 2014 Posted July 8, 2014 Paul, on the mark 1's, poke a screwdriver into the opening on the gangway corridor and push in and up. This will pop the roof ajar. Remove and everything else will fall apart easy enough.
0 burnthebox Posted July 8, 2014 Author Posted July 8, 2014 Paul, on the mark 1's, poke a screwdriver into the opening on the gangway corridor and push in and up. This will pop the roof ajar. Remove and everything else will fall apart easy enough. Is that at the top or bottom of a Lima coach,
0 Glenderg Posted July 8, 2014 Posted July 8, 2014 Is that at the top or bottom of a Lima coach, the rectangle above the circle. Pop the screwdriver in there.
0 burnthebox Posted July 8, 2014 Author Posted July 8, 2014 (edited) Now that I'm back from the Hospital having had the screwdriver removed from my hand, got 27 stitches, tetanus injection, blood pressure & temperature checked, the nurses were great, being very careful, I'll be able to use the screwdriver again next week, anyway glenderg you got an easy one, my lima has no rectangle above the circle, cos there is no circle, by the way I'm only joking about the hospital, really, helps to lighten the mood, and thanks guys Edited July 8, 2014 by burnthebox
0 burnthebox Posted July 8, 2014 Author Posted July 8, 2014 Sure it's a Mk 1? Just checked & found out it's a MK2a
0 burnthebox Posted July 9, 2014 Author Posted July 9, 2014 There all MK2as, but only the Lima has screws, other 2 are Hornby
burnthebox
11 answers to this question
