C.I.E. 32XX Conversions
iarnrod
In 1978, CIE converted the following Brake/GSV coaches from earlier built coaches :
3213
3214
3215
3216
3217
3218
Can anyone confirm the original coach numbers of these coaches? CIE frequently put the original coach numbers on their drawings of carriage conversions around this time, so if anyone has a drawing for these coaches, chances are it has the original numbers on it.
I have a list of unconfirmed numbers for these coaches, but trying to get a confirmation. IRRS Journal, or any other publication where one would normally look, does not list original numbers for these coaches.
Any help greatly appreciated.
13 answers to this question
The full list of conversions for the 32xx vans is:
Brake Standard GSV
3201 converted from 1339
3202 converted from 1350
3203 converted from 1347
3204 converted from 1340
3205 converted from 1341
3206 converted from 1348
3207 converted from 1349
3208 converted from 1354
3209 converted from 1355
3210 converted from 1351
3211 converted from 1352
3212 converted from 1353
GSV
3213 converted from 2580
3214 converted from 2587
3215 converted from 2588
3216 converted from 2589
3217 converted from 2590
3218 converted from 2592
Brake Standard GSV
3219 converted from 2578
3220 converted from 2577
3221 converted from 2586
3222 converted from 2584
3223 converted from 2572
3224 converted from 2582
Edited by josefstadt
Many thanks for that, Josefstadt. Much appreciated
Can I ask what your source of information is for the 3213-3218 coaches please, as all the other numbers tally with the numbers that I have for those coaches, but the 3213-3218 ones differ to what I have?
Crude copy of the C.I.E. drawing that I have for 3201-3212 lists 3202 as ex-1347 and 3203 as ex-1350, so just wondering if you confirm source for those ones aswell please.
Thanks once again.
Edited by iarnrod
The source was the CIÉ Coaching stock register which I obtained a copy of from the Technical Office in Inchicore during the 1980s. The data above came from the pages detailing the 32xx vans. However, when I checked the pages showing the 13xx Standards the conversions you have, i.e. 1347 to 3202 and 1350 to 3203, are listed. So someone made a transcription error when making the notes on the original register. Unfortunately I have no way of knowing for certain which is the error, but as your info comes from a drawing it is likely that that is the correct sequence.
Iarnrod, a bit more info on the history of the 32xx vans. The first series, 3201-12 was straight forward with the donor vehicle being as built originally - e.g. 1339 remained as built (apart from cosmetic changes) until conversion to 3201. However, the other two series, 3213-18 and 3219-24 were more complicated with the donor vehicles going through a number of changes before conversion into a 32xx type van. In the list below the the progression is from right to left. Note that the change from a 21xx Composite to a 16xx Standard did not involve structural alterations and was really just a reclassification of the first class accommodation to standard class. The dates given are probably when the work was signed off rather than the entry of the vehicle into traffic.
Brake Standard GSV
3201 (24/06/77) ← 1339 (1951)
3202 (24/06/77) ← 1347 (1951)
3203 (01/07/77) ← 1350 (1951)
3204 (08/07/77) ← 1340 (1951)
3205 (15/07/77) ← 1341 (1951)
3206 (25/08/77) ← 1348 (1951)
3207 (08/09/77) ← 1349 (1951)
3208 (15/09/77) ← 1354 (1952)
3209 (11/10/77) ← 1355 (1952)
3210 (27/10/77) ← 1351 (1952)
3211 (24/11/77) ← 1352 (1952)
3212 (21/12/77) ← 1353 (1952)
GSV
3213 (10/02/78) ← 2580 (07/03/74) ← 1620 (00/11/72) ← 2128 (1951)
3214 (23/03/78) ← 2587 (21/05/74) ← 1345 (1951)
3215 (12/05/78) ← 2588 (27/05/74) ← 1346 (1951)
3216 (07/07/78) ← 2589 (16/08/74) ← 1342 (1951)
3217 (25/08/78) ← 2590 (16/08/74) ← 1343 (1951)
3218 (15/09/78) ← 2592 (16/08/74) ← 1344 (1951)
Brake Standard GSV
3219 (16/07/80) ← 2578 (16/02/74) ← 1622 (00/11/72) ← 2125 (1950)
3220 (23/07/80) ← 2577 (01/02/74) ← 1614 (00/11/72) ← 2152 (1954)
3221 (22/08/80) ← 2586 (03/05/74) ← 1625 (00/11/72) ← 2155 (1954)
3222 (12/09/80) ← 2584 (09/05/74) ← 1615 (00/09/72) ← 2134 (1952)
3223 (17/09/80) ← 2572 (00/12/73) ← 1611 (30/06/72) ← 2144 (1954)
3224 (21/10/80) ← 2582 (12/04/74) ← 1623 (00/11/72) ← 2132 (1952)
That's interesting re 2128. Almost certainly built originally on an earlier GSR (Bredin era) chassis.
I think CIE just followed the "standard" length for the first batch of compos in 1951. The change to 61' 6" was to allow the compos from then on to have four 1st and three 3rd class compartments, rather than three and four respectively.
Answer this question...
