Forum login not remembered on iPhone
I have to login again every time I access the forum using iPhone which uses the mobile template. Not a problem on iPad which uses the full site template and no problem on desktop browsers. It seems to be related to the phone sized template
You should be able to set the device to 'remember password' and also ensure you have enable tracking and cookies enabled.
If your privacy settings are too tight the forum can't maintain your session which could be causing it to keep requesting your credentials.
  • 3 months later...
I have the same problem only it's my iPad I have to resign every time
Any joy with this issue? I have to login every time on my iPhone but the login "remember" ok on my iPad and Mac. I suspect it is to do with cookie storage due to the mobile theme's different url.
