I gave my MM201, 222 a run (it has not had a run in ages), this eve on my small layout. The power supply is through a basic Hornby DC controller, the loco was chipped in the past but I now only bother running any of the locos on the DC as I find it fine for what I want in a small set up. The problem seems to be that the loco runs for a circuit or two of the layout then slows to a stop. It is very like it is causing a short as I have to disconnect and then reconnect the power supply before she will run again. I removed the dcc chip and tried running her with a blanking plate, in all cases she runs for a short time then stops. Would anyone have any ideas or suggestions about the possible problem and solution please?
I have ran 141s this evening on the same set up and they seem to be running fine.
Sulzer201
Hi all,
Thanks in advance, Tommy.
11 answers to this question
