Ok so far I have fitted DCC sound to a few Murphy Model 141/181s by installing a basic speaker in the speaker cradle provided inside the MM loco body. Really quick and easy to do all that was required was to lift off the loco body, solder the two speaker wires to the locos circuit board PCB at SP+ and SP-, plug a 21 pin sound decoder in (LokSound or Zimo), put the body back on and go. About 10-15 mins work and no cutting.
However I decided to try a DC Kits supplied LokSound decoder with baby GM recording but with an enhanced bass reflex speaker. As the speaker is in an enclosed rectangular box it would not fit in the speaker cradle of an MM 141/181 nor even inside the Loco body with out some cutting and fettling to get it to fit in. It took me about 90 minutes as I was being careful to measure and weigh up options. A lot of work compared to dropping a basic speaker in the MM cradle.
Take loco body off (leave walkway side rails in place)
Remove the supplied plastic speaker cradle - 2 screws
Cut the two metal lugs off the metal chassis top that received the cradle screws (disc cutter)
Cut away a raised section of the metal chassis just in front of the PCB (disc cutter)
Cut away a small section off the underside end of the bass reflex speaker box (doesn't effect sound quality). The alternative to this is to cut a few millimetres off the end of the circuit board, but I decided not to bodge the loco anymore than I had to. (saw + knife)
Remove the beige plastic support under the loco body roof grill - 2 screws (this obstructs the speaker box)
Cut and file away the plastic lug on the inside of the loco body roof that received the rear most screw from above
Plug the decoder in (which is prewired to the speaker) and place speaker box over the area where the cradle used to be with the cut away bit overlapping the circuit board
Put the body carefully back on and pop the walkway rail ends back into both cab sides.
Ok, got it done and it sounds great, but to be honest I won't bother again with all the hassle to fit a bass reflex speaker. In future I will instead just remove the beige plastic support from under the roof top grill which will let a lot more sound out of a standard cradled speaker. I didn't like bodging these lovely locos.
I will post more on the sound quality and DCC operation later perhaps with a video clip. In summary, it sounds better than the Zimo with standard speaker, but doesn't drive as well (i.e. sound not mirroring throttle inputs quite as well). Ah well can't have everything.
Overall though it is very good and the best sounding baby GM engine I've heard so far.
PS: I would love to hear this recording in the future with the new LokSound 'Full Throttle' decoders because I suspect the drive and notching would sound and behave more realistic.
PS2: I really liked the F3 long horn and F8 distant horn sounds, but the F2 short horn sounds awfully weak.
Noel
http://www.dckits-devideos.co.uk/shop/dcc_digital_loco_sounds/irish_diesel_loco_sounds/class_141_gm_bo_bo_dc_kits_.php
Edited by Noel11 answers to this question
