Rob Posted June 25, 2019 Posted June 25, 2019 Hi. Any suggestions of where l could source decent Fencing for OO gauge railway yard along the lines of that at Heuston attached? Something that doesn't require to be painted preferably !! Cheers. 1 Quote
DiveController Posted June 26, 2019 Posted June 26, 2019 Not ideal as you'd have to add the solid portions by hand but just in case you don't find an alternative? Bachmann 44-562 - 5 x Model Plastic Metal Fencing Grey 00 Gauge 1 Quote
popeye Posted June 26, 2019 Posted June 26, 2019 Try Ratio or Knightwing, most big model shops should stock them. 1 Quote
JasonB Posted June 26, 2019 Posted June 26, 2019 Have to agree with Popeye. Knightwing or Ratio are definitely worth a look if you don't mind some kit building. Ratio in particular have some really nice options, and you get that little bit more for your money. The Bachmann stuff is perfect for a quick fix without any hassle, but it's a tad more expensive. All depends on how much you're planning to install I suppose. 1 Quote
