Beynac Posted July 26, 2019 Posted July 26, 2019 Hello, what's the best way to glue a grass mat on the baseboard ? Thanks.
Joe Keegan Posted July 26, 2019 Posted July 26, 2019 Copydex , if it doesn’t work out then you can remove it without damage to baseboard. 1
KMCE Posted August 26, 2019 Posted August 26, 2019 This is certainly an alternative if your up to it?? PS - I recommend you wear welding gauntlets......... 1 1 1
jhb171achill Posted February 10, 2020 Posted February 10, 2020 On 8/26/2019 at 9:46 PM, KMCE said: This is certainly an alternative if your up to it?? PS - I recommend you wear welding gauntlets......... VERY realistic scenery!
David Holman Posted February 16, 2020 Posted February 16, 2020 Not green though, so really ought to be dyed before planting in PVA. Not sure it would like being ripped off after the glue dries either.
