Everything posted by Darius43
Some more embankment slopes grassed up… Cheers Darius
Completed embankment slopes installed on the layout. They are designed to be push fit only (i.e. not glued in place) so they can be removed to get access to point motors etc. for the upper track level. Cheers Darius
Scratch built using card, acetate sheet and brick paper. To go in one of the back yards of the row of terraced houses I am building. The plants are ready made items from eBay. Cheers Darius
Engineering Works (of course it does). Modified Scalescenes free download “low relief” kit. Cheers Darius
Well spotted. They will get a repaint and weathering at some stage Cheers Darius
And more… Cheers Darius
Some more… Cheers Darius
Hi George. They were 3D prints obtained from eBay. Cheers Darius
Shrubbery… Had to apply then this way up as they kept rolling down the slope the other way… Flocking next… Cheers Darius
Some more progress. The joint will be static grassed “in situ” on the layout. Cheers Darius
woke up this morning… …and got plastered. Cheers Darius
Embankment sides cut from polystyrene blocks using a hot wire cutter. Cheers Darius
Wizard Models (ex Comet) brass sides grafted onto a Dapol donor coach. Phoenix Precision LMS maroon thinned and airbrushed on. HMRS Pressfix lining, lettering and numbers. Cheers Darius
The 80 Class and 70 Class threads on RMWeb now have the missing pictures restored. Cheers Darius
Tested the two MPDs on the Middlemark layout today. They can just about propel themselves but pulling wagons is a no no, with wheel spin on R3 curves. Some more weight around the motor bogie is needed. Watch this space… Cheers Darius
You mention this often and contemporary photos show them. That said I’m afraid that I’m not prepared to go over these models with a hammer and centre punch. Cheers Darius
MPDs DCC fitted, tested and boxed ready for “running in” on the Middlemark layout this coming weekend. Also boxed something for them to pull along… Cheers Darius
Modified Freightliner Flat couplings on test on the layout this morning - works successfully so far Cheers Darius
