Darius43
Everything posted by Darius43
  1. Now only 6 more to go… Train-Tech tail light fitted to last wagon. Cheers Darius
  2. Some more wagons converted… Only 13 more to do… Cheers Darius
  3. Hornby MGR wagons modified so as to be a permanently coupled rake. I first replaced the large Hornby tension locks with pivoted magnetic couplings but the pivoted connection wasn’t strong enough and there were several failures in service as seen below. These couplings are now being replaced with hone made fixed bar couplings made from black plasticard - as used on the rake of Hornby Freightliner flats that I modified a year or so ago. Four wagons completed - a lot more to go. The coal loads are a mixture of cast resin loads (from eBay) and Wills plastic coal loads with real coal bits stuck on with diluted pva. The Hornby MGR wagons themselves are all from eBay obtained at minimal cost. I replaced the Silver Seal wheels with metal ones and “tidied up” the roughly applied weathering using an airbrush. Cheers Darius
  4. Rake completed I have ordered a couple more - for the white/yellow/green liveried Tarmac versions. Cheers Darius
  5. Train-Tech battery operated flashing LED tail light modified to fit inside the hollow tank body. Cheers Darius
  6. Only two more to go to complete the rake. Cheers Darius
  7. Two more completed. Four more to go… Cheers Darius
  8. The MGR train did several circuits after which the magnetic couplings began to fail as shown below. The couplings are from West Hill Wagon Works and are the latest of several failures I have had with their couplings. I am forced to conclude that they have a good concept but their execution and engineering is poor. Alas I won’t by buying anything else from them in future. I plan to make my own fixed bar couplings (like I did with the Freightliner Flats) and create permanently coupled rakes of 5 wagons with tension locks at each end. Cheers Darius
  9. Watching the trains go by in the shed today Cheers Darius
  10. Decals applied followed by some light weathering. Cheers Darius
  11. A couple more of the 3D printed JGA cement wagons detailed up using brass rod, tube and electrical wire. Followed by a coat of grey primer, with air hoses and buffer’s picked out in black enamel paint. Cheers Darius
  12. Finally got roundtuit and completed the Snow and Ice Treatment Train wagons (3D printed kit). Cheers Darius
  13. Nope - hit “post” too early Cheers Darius
  14. Running session in the shed today. Cheers Darius
  15. Dummy (non-motorised) Class 66 made from spare bogies, chassis and body sourced from eBay. For running on trains that have a loco at each end. We tried running these trains on the layout with powered locos at each end but could not get them to match speeds over the full throttle range - resulting in the train being stretched or scrunched. Cheers Darius
  16. Mk1 Pig completed. I remember queuing up with my Mum and sister in the street beside the Avenue Cinema in Belfast one evening back in 1978 to see the film Grease. We had just moved to Belfast (Dad worked for Michelin) and the street was fenced off down the middle as the Grand Central Hotel next door was being used by the Army. Vehicles like these were being prepared to go out on patrol. Both the cinema (a real flea pit as I recall) and the hotel are long gone and the Castle Court shopping centre occupies the space today. 1:48 scale Alvis Saracens - HLBS resin kits. 1:50 Alvis Stalwart Mk1 - modified Verem diecast model. Cheers Darius
  17. Humber “Pig” Mk1. 1:48 scale 3D printed kit from eBay. The model as printed is fairly basic with little detail. The bull bars were fitted to the Mk2 so we’re not used. I added more details using bits of plasticard and brass rod. Cheers Darius
  18. Some more 3D printed 1:48 scale AFVs cleaned up and painted. FV434 Ferret Mk2 Cheers Darius
  19. Trojan AVRE completed. Cheers Darius
  20. Some more 3D printed 1:48 armour. FV721 Fox Armoured Car FV214 Conqueror Tank Five generations of British Army MBTs. 1:48 scale kits from ASAM Models and Empress Miniatures - plus the 3D printed Conqueror. Cheers Darius
  21. About 15-20 years ago. They were based on older MTK kits but sadly the proprietor of No Nonsense Kits passed away in 2010. Darius
  22. No Nonsense Kits CIE A Class Kit Missed out on an IRM A Class and want to experience pain and despair*. Here’s the kit for you. Cheers Darius * A bit harsh I know as No Nonsense Kits are cleaned up and improved Modern Transport Kits.
  23. Well spotted. Yes - a Mk2 in 1:48 scale from the same supplier as the Trojan AVRE. Cheers Darius
  24. Trojan AVRE. 1:48 scale 3D printed resin kit with three parts - found on eBay. Basic painting completed. Finer detail painting plus registration and lights to be added. Cheers Darius
  25. Sunstar 1:24 Diecast Routemaster with new home made number, destination and advertisement decals. Cheers Darius
