Junctionmad
wasn't that the point of 1522, when CIE withdraw the last of the 24xx series , they converted the 1522 into a kitchen car
if you stay in 00 gauge and bullhead you have the option of (a) PECO new bullhead track , quite nice , even if the chair detail is somewhat generic , code 75 nickel silver (b) C&L , two types , original with thin sleepers , and FASTTRAK which has an exactoscale think sleeper base, nice chair detail , code 75 nickel silver © SMP plastic sleeper , thin sleeper base, code 75 nickel silver , (d) DCC Concepts , code 75 stainless steel , thick sleeper AT present none of these companies can supply ready to lay points, so you have either to wait for PECO ( but only one type of point ) or build points for scratch or kits Note that , I posted a review of C&L and DCC on here somewhere , personally I wont touch stainless steel track , far to hard to work and requires specialist fluxes and solders ( why DCC bothered is beyond me ) certainly of the MSWR sections of CIE , right up till recently ( 2010) there were siding still in light weight flat bottom track , this could be modelled with PECO code 65 flat bottom, simply glued to ply sleepers , at present there no solution for the CIE chair that was sometimes used under the FB rail ( cant speak about the GNR )
The only issue with that is you are likely to need compression in a model layout, personally Id take one of the many layout design software apps and build by layout in that first , to see what the ultimate dimensions are
thanks re Claremorris, its a big undertaking , but I'm a builder as much as an operator and its a interesting challenge , using 00-SF I can at least run off the shelf plain track etc
its not a track formation , I can say was common in ireland, most single line stations were very simply " tracked " with the goods siding typically in advance or in the rear of the station and primarily designed to be accessed in the direction of the majority of traffic , typically " from " Dublin etc . Land was comparatively cheap in ireland and many stations were quite sprawling, presenting challenges in model form The formation you mention is more common on double lines, where the B of T rules frowned on facing points , so one line had to cross the other to access the yard. IN recent years the use of facing points is less frowned upon and such complexities are largely gone
Great, getting handmade track built cheaply isnt a reasonable assumption, its time consuming work, and hence relatively expensive, suck it up as the americans say This is a perennial issue for exhibition layouts ( and one my club finds difficult to resolve ) . challenging layouts by definition are " challenging " and at exhibitions , punters want to see trains running ( if you have ever manned an exhibition layout, its interesting to see how fast people drift off, when no stock is moving ) . Hence layout that require shunting, cross track movements etc are likely (a) to need multiple operators ( b) more likely to stall or derail and (b) often dont hold the publics interest My club is currently deciding to build far more complex ( in comparison ) exhibition layouts , one that will inevitably require multiple operators and will work to signals etc. But its a big undertaking Home layouts , where there is nothing to prove , is where you find much more complexity SO im in the early stages of modelling claremorris in the 70s , 50 points , 5 single line junctions, massively signalled to support " knock " specials ( 10 passengers trains in the station at one time !) and also the attached ballinrobe branch ( which I have committed to exhibit next easter, --- gulp , just the branch mind you ) but without huge amounts of automation, running this whole layout at exhibitions will require 3-6 operators , a very big commitment In my case I actively sought out a complex track plan, and its the reason I'm doing it in 00 , because in anything else , there is not a hope Id complete it inside 10 years . Most layouts in ireland that are complex, are simply too big to model , and applying huge compression, results in an untenable layout. Then again most track work in ireland , even in steam days , was relatively simple, with few uses of complex ladders and slips etc , unlike what was common in the UK ( where traffic densities where orders of magnitude higher ) Railway modelling is full of " biting off more then you can chew ", people massively underrate the time it takes to build a good quality layout, especially where there is any complexity
Here is what is available , whats missing is a check rail gauge , arguably the most useful gauge 95A Track gauge, Type 'A', Rollergauge - 5' 3" Gauge (21 mm) �5.20 1 190A Track gauge, triangular, for automatic gauge widening - 5' 3" gauge (21 mm) �9.50 1 ( thats your three-point gauge you were looking for ) RSGA Roger Sander's 'Mint' gauge for fine tuning pointwork - 5' 3" gauge (21 mm also these standard gauges are useful 192 Flangeway gauge �4.50 1 DDW01 Block gauge with crossing alignment aid (DD Wheelwrights) In my experience, its was the need to build large amounts of plain track, that put me off 21mm, the pointwork is the fastest side of track building, constructing and laying " miles" of plain track inc fiddle yards etc , is what put me off Again the only difference between 21 to EM as opposed to P4 standards , is the wider flange-ways and the point blades have to have a wider gap when open. Everything else is the same. back to back are then eased over P4, which helps to reduce running radius
I build my own point work for my Irish layout in 00-SF. There would be no cost difference in pricing in a 21mm point. depending on what level of details ( chairs etc ) , a handbuilt point is cheaper then a PECO large radius point. This is , of course, building it yourself. Secondly I would suggest that you consider building your own track work, Humbly,I suggest, If you dont have the engineering skills to build a point ( which is a simple process ), then I suspect you will find converting stock equally challenging PS there is no need to buy c&L points kits, the sleeper lengths will be wrong anyway. Nor do you need to source templates Simply print a correct 21mm template from Templot, and then if you wish you can use C&L pre-made switch blades ( 16 quid a pair ) and buy their crossing Vees etc. However if you can use a file ( and buy the Scalefour filing jigs) then you can make your own in about 30 minutes. Templot templates are much more accurate anyway then the the Societies or C&L templates , some of which have suffered from scaling errors over the years If you dont have a background in this , then dont jump until you understand all the compromises Note that no-one makes a check rail gauge for 21mm to EM standards ( nor do they make it for 21mm P4 i think ) ( which is more the pity ) , if you go 21mm to p4 standards , beware of the implications for rolling stock , the quality of track work and laying it etc Note that roller gauges can be easily made from bolts and washers etc and verified by a micrometer, and you can easily build 3 point gauges with some judicious filing you need a track gauge , a flange check gauge and a flange way slim to build a point, a 3 point gauge is useful for laying plain track p4 is a world away from PECO , in order to get it running well.
could I suggest you join the society , its cheap and very useful no matter what 4mm gauge you model in
This isnt quite correct, the slightly wider modern EM wheels will have little effect on loco dimensions , valve gear and splashers etc are not effected. Nor is there any reason to reduce the gauge to simply model in 21mm to EM flange ways. Its all about the crossing flange ways
Photos for future modellers
Junctionmad replied to jhb171achill's topic in Photos & Videos of the Prototype
Could I make a plea to remember to photograph the infrastructure, signals , small stuff in yards, building etc. This is typically stuff that's bulldozed with little record , whereas we have zillions of loco pics. Thanks everyone that takes a photo -
Consideration could be given to modelling 21mm to EM flangeway standards, this would allow radius down to about 2'10 and hence could get round in a 6' shed, it also removes the need to compensate locos and wagons , EM has 1mm flangeways as opposed to 0.68mm for p4. 00 style wheel set on longer axles can then be used and trackwork is a little more forgiving Visually, you then have 21mm but running models is a little easier and less precise You'd need custom track gauges, but that's not that difficult to make etc
Visited the Gauge O guild premier show today. Well worth a visit, a real " builders " show with loads of traders and obscure ones at that. Venue was excelant too
I would rate the proxxon as well better then the dremel having had both. The Proxxon is smother and better made
remaining mechanical signal cabins in ireland
Junctionmad replied to Junctionmad's question in Questions & Answers
I find that strange as abbey is closed AFAIK , and the line is run under engineer possession , effectively one engine in steam, which doesn't require signalling -
ALERT - Photo hosting web sites - disabling links
Junctionmad replied to Noel's topic in Site News & Help
All these free sites should carry a health warning " warning , you will be ultimately screwed " When will Flickr follow ? Anyway rip photobucket , how to kill your business in one " easy " decision -
just a follow up shows a galway train with a TPO and its one BSGV hooked up at the top of the Galway train , proof that on occasion older stock got attached to Mk2 trains
looking for a suitable GRILL for the MK1 BSGV conversion
fo those that are still interested , As Im doing the conversions , I keep coming across BSGV photos I think originally this list came from Glenderg 3172 former BR BCK 21138 3173 former BR BCK 21146 3174 former BR BSK 21143 3175 former BR BSK 21196 3177 former BR BSK 34227 3178 former BR BSK 34590 was also air brake through piped 3179 former BR BSK 34677 was also air brake through piped 3180 former BR BSK 34378 was also air brake through piped 3183 former BR BSK 34687 was also air brake through piped 3184 former BR BSK 34566 3185 former BR BSK 34093 3186 former BR BSK 34757 was also air brake through piped 3187 former BR BSK 34012 was also air brake through piped 3188 former BR BSK 34701 was also air brake through piped 3189 former BR BSK 34264 was also air brake through piped but I can confirm that 3174 is a conversion from aa BCK and not a BSK ( there is a picture of 3173 ) in the fred dean flickr albums note according to Doyle and Hirsh 3171 to 3176 , 6 vehicles were all converted from BCK Mk 1 stock and 3177 to 3192 were from mk1 BSK -
Shorter couplings for MM Cravens and Mk2s?
Junctionmad replied to Noel's question in Questions & Answers
The main issues around NEM pockets is two fold One is it's a HO standard and this has lead to 4mmmanufacturers making incorrect assumptions. Secondly ,00 rtr manufactures have either by error or by wilfull decision have misplaced the pocket In the US No manufacturer would buck the NMRA standards without good reason. But 00 rtr has suffered from weak standards. Even though the Double O Gauge Association has issued a NEM pockets standard for 00, this organisation is largely ignored. -
Reading the resources on kadees , I don't believe the NEM versions are a solution -
IN my quest for suitable louvres for the BSGV, I hit on a neat way to make them from raw plastikard what I did was mount a 45 degree craft cutter ( a robust one with a circular shaft from an old craft knife set ) into my proxon pillar drill and turn the cutter so its produces " kerfs" that sit at right angles . ( the drill is not rotating ) I have the advantage of then using the X-Y table and I incremented it in 0.6mm X increments , The Y increments simply draw the knife through the material The prototype has 32 louvres in height and this method closely resembles that number Here it is fixed into the modified Hornby Mk1 sides ( awaiting a little tidy up here and there ) Note the funny effect ¼ from the bottom seems to be a lighting effect , in real life , I cant see it in fact the odd defect add to the realism as in practice the louvres suffered damage all the red dust on the XV table is because I milled out the back of the windows so as to recess the glazing closer to the outside as the glazing on the old Hornby MK1 is very far back from the outside B5 bogies from replica railways, some Keen systems LMS suspended corridors , some wire detail and better under frame detail ( diesel tanks etc ) are next on the list -
Wow, Given my humble efforts at painting . This is light years away for me
thanks , I have 12mm on order -
A question Whats the right diameter wheel for the B5 Bogie as used on the converted BSGV regards Dave
