Irishrailwayman
Everything posted by Irishrailwayman
  1. As opposed to an "oil burner" for a diesel outline...
  2. The track has been painted chocolate brown and the side of each rail has been painted with a rusty wash. The edges of the track area are here shown with masking tape ready for the application of fine grey loose ballast...
  3. Jhb, The backscenes I use are from Gaugemaster.com selecting the one closest to my prototype. They come in just the right size (4.5 feet by 6 inches) for this layout configuration but they are made in larger sizes also (9 feet by 12 inches, I think). It strikes me that with modern drone/camera technology it should be possible to take a series of linear digital shots of a location background from an appropriate height to simulate the 4mm/foot illusion of distance. The photos could be merged and touched up by computer before printing out on a long flexible photographic sheet for mounting onto a layout backdrop. I notice a company advertising in BRM called Quality Backscenes offering a similar service (www.qualitybackscenes.co.uk ; studio@qualitybackscenes.co.uk). Might be worth checking out.
  4. A couple of shots of some scratch and kit-built buildings prepared for Llanuwchllyn and placed roughly where they will go on the layout. Next steps are to fill in missing sleepers and start the ballasting...
  5. The model railway community in Ireland, I am guessing, is tiny compared to the UK. ROI has three (?) main active clubs with a few more modellers scattered widely. NI has a few more clubs. UK has a huge MR community with numerous exhibitions on practically every weekend of the year whereas ROI has two (?) main exhibitions with a couple more in NI scattered over the whole year. Junctionmad has shown his work on hand-made points at Wexford MRC recently so it does not seem overly difficult. However, the prospect of making points, lengths of track not to mention resizing every engine, wagon and carriage in a collection is daunting indeed even if the end result is tempting. The fear would be that after all that effort, the running would be poor as can happen even with best efforts with rtr stock. Also many modellers here do model UK outline given frequent visits there and the more ready availability of rtr items. By the by, South Dublin MRC have done a layout called Belturbet with broad gauge 21mm and narrow gauge 12mm track.
  6. Looking forward to welcoming SVLR to Wexford at Easter!
  7. To illustrate: Push rods under Cynwyd Llanuwchllyn mimic diagram with push-to-make buttons controlling turnouts in pairs to make the road required:
  8. What about an Irish variation on Shunters Yard (4 feet X 9 inches)...?
  9. Of course you do, go on, go on, go on, go on....
  10. For Cynwyd in N I used push wires under the baseboard which are the simplest. For Llanuwchllyn I am using side-action motors at the back of the layout operating the push-wires underneath activated by push buttons/CDU on a mimic control panel. See my threads on IRM.com on each layout for pics.
  11. I have used a OO kit from First Class Trains previously which included a rechargeable battery, on/off switch, recharge socket/plug/wiring, copper strip and LEDs/resistors. A red LED lamp could be added to provide a rear lamp to brake ends. You had to buy a transformer which could take 10 coach leads. They now only supply them with wheel pick-ups. I have thought of using the Train-Tech kits for coach lighting but would prefer an on/off switch (for use when transporting stock - no point them being lit up in their boxes) and ready access to change batteries. No doubt the kit could be bashed to provide these.
  12. That's true but they have the advantage of enabling wagons to be removed from the centre or other part of a train without disturbing the others (something that is difficult with Hornby-style couplings). They can add stability to trains over less-than-perfect track quite apart from delayed uncoupling capabilities for shunting.
  13. The same could be achieved using the shorter NEM Kadee couplers.
  14. Wrenneire: No photie just a Photobucket logo?
  15. Are these electrofrog or insulfrog points and are they correctly wired? Older rolling stock may have wider wheels which can cause problems also.
  16. Good progress on Llanuwchllyn with all wiring completed, tested and working fine in both manual and automatic modes. The track is also finalised and ready for completion of sleeper gaps and ballasting. Initial work has commenced on buildings some of which will need to be scratch-built. Then its a case of painting/weathering the buildings and developing surrounding scenery to the standard achieved with Cynwyd. A couple of shots of the track first: Next some of the buildings placed before painting: Finally, a couple of views of the electrical control panels - note the use of side-action motors at the back which allow manual operation if desired (the push button control panel controls the points as pairs to make the appropriate road for the trains).
  17. Tony, for what it is worth my thought processes in developing my model railways run along the lines of: can I store it where I can see it; can I access it to run it at home; can I dismantle it easily; can I transport it safely in my car and exhibit it multiple times...
  18. Noel, I missed this posting first time around so forgive my not responding previously with my thanks for your appreciation. Gerry
  19. Thanks for that - it is almost 10 years since I laid that backdrop down! I first pasted on Peco Cloudy Sky paper as a backdrop. Then I cut out the scenic section of an Auhagen Wooded hillsides background mural No 42 511. This was pasted on top of the sky paper which gives an effect of relief. This also has the pleasing effect of the clouds seeming to drift from behind the wooded hills. Gerry
  20. Noel, might be nice to run this around Ballybeg and capture a video of the views from the cab - sometime perhaps when you are down this way with David perhaps?
  21. Noel, It would be great to set this up at an exhibition with a monitor for the public to view the unfolding scene from the cab - consider that an invitation to the Wexford Easter Exhibition 2018!
  22. Looks great through the cab windows!
  23. A couple of views from the Kilkenny Show. Huge crowds passed through and the model railways got a good reception. Kilkenny 1.JPG 757 kb · Done Kilkenny 2017.JPG 727 kb · Done × Pasted as rich text. Paste as plain text instead Drag files here to attach, or choose files... Accepted file types gif, jpeg, jpe, jpg, png Insert other media Uploaded Images Kilkenny 1.JPG 757 kb · Done Kilkenny 2017.JPG 727 kb · Done Kilkenny and Shunters Yard.JPG 773 kb · Done
  24. Hi Enda, nice to meet you at this show. We were mainly on model railway "missionary" work there among the farm/military modellers!
  25. Actually that's Eamonn's own diorama and very good it looks too.
