MikeO
Everything posted by MikeO
Peter In both cases I used the whole model. For the 071 the donor was a Class 37 diesel and for the 121 it was a class 20. The choice of these models was influenced by the fact that they were about the right length and had the correct wheel arrangement. I thought it would be simpler building up the body to the appropriate shape. I am content that it looks the part but may not be strictly accurate. Hope this helps.
The Mark 4 coaches look well how do you intend coupling them? I also like the container wagon chassis. Is this your own design? MikeO
The Cregagh show went very well considering the prevailing conditions. A number of exhibitors decided against attending and numbers of the public were not great but I believe the organisers were pleased with turnout. For a small show there was a good range of food available for the public in a dedicated eating area designated "The Buffet Car" Below is a selection of photos covering most of the layouts present. T Trak overview Two shots of a cattle train on T Trak Also a photo showing some card 6 wheels, scaled down Alphagraphix 00 gauge kits. the 3 coaches on the left. Killagan St Columbas Club from Belfast a new one to me Stirks Corner an 00 Gauge layout Several other N Gauge layouts. I did not record their names. MikeO
Kieran Very impressive captures the look of the real thing. The extra detail should make it even better. The 2nd photo in the sequence reminds me of a Shapeways N Gauge Generator van I was given. There was a lot of stratification which I found very difficult to make smooth. Even though it seemed smooth enough to paint, once done the lines were still visible. on the track it looks fine but closer up not as good as would have liked it to have been. I hope you will be able to get a good fonish on the final print. MikeO
The coach looks good. For cutting thin card ie upto about 300gsm I use Scalpel blades with an appropriate handle. The blades are very sharp and need care when handling but when new make cutting windows etc much easier. For cutting mounting board etc I use a new blade in a rigid utility type knife. Those with snap off blades are too thin to make good cuts in mounting board. As with all cutting patience and plenty of practice are essential. For attaching bogies I use two different methods Fleischmann track screws which are expensive and small brass screws about 8mm long a pack of about 10 cost around £2. I got mine in a local craft shop but it closed a few weeks ago. Attached are a few photos showing each method. Using the brass screws is easiest as the head fits neatly into the hole in the bogie and is my preferred method. The first photo shows the brass screw method. The second photo shows the screw which is a size 3 and sold as 3/8in long (8mm) The third photos shows the Fleischmann screw method. These are very thin and require support to keep the bogie in place. I use a small roundish piece of plastic or thick card (the white pieces below the screw head). To keep the bogie wheel from fouling the floor or chassis sides I use a small plastic washer. A piece of plastic card or paper card of the right thickness would also work. In photo 4 the plastic washer can be seen under the bogie. Photo 5 shows the washer and photo 6 shows the box in came in. I got mine from Woodies in Dundalk. I think they cost around €2 MikeO
- 19 replies
- 1
- rolling stock
- card
(and 1 more)
Tagged with:
The magnetic clamps look useful. I see the yellow ones are contained in the N gauge Pack of tools. Would they fit inside N gauge coaches. I got some white magnetic clamps from York Models which are fine for larger N gauge buildings but are far too big for use in the coaches. MikeO
- 19 replies
- rolling stock
- card
(and 1 more)
Tagged with:
Thanks jhb that is a good tip about the match sticks. I find that straightening the corners and making it all square can be fiddly. they should help and also make a better fit for the roof. MikeO
- 19 replies
- 1
- rolling stock
- card
(and 1 more)
Tagged with:
The models look very impressive. 3D printing has a lot of advantages but for me the big draw back would be the initial drawings whether in CAD or Sketchup. MikeO
An interesting construction method. I suspect it requires a lot of careful drawing and cutting. It might useful to apply strengtheners to your existing coach body at each end and/or along both sides or at specific intervals. I use mounting board but a couple of pieces of 200gsm card laminated together and then glued to the ends and aside would also help. If using thinner card more pieces would be needed. Even if you do not keep this coach body you will get good experience. You might have to strengthen the roof also usually a second piece about 1mm smaller all round is sufficient. MikeO
- 19 replies
- 2
- rolling stock
- card
(and 1 more)
Tagged with:
Very good start. Nice clean and neat lines. is this the shell or have you added the skin? I found that using a piece of round dowel rod or round knife handle helps in curving the roof if it is made from card. Takes awhile though to get a good profile. MikeO
- 19 replies
- rolling stock
- card
(and 1 more)
Tagged with:
NIRCLASS80 Thanks I missed that post. I just got the flyer yesterday should have checked. MikeO
Hi Folks A new railway exhibition is being held this year. See Flyer below. I believe there may have been previous exhibitions the last of which took place around 2013. Any support will be welcome by the organisers MikeO
HI LostCarPark The data sheet is very interesting. With regard to card rolling stock I have created a new thread so as not to take this one off topic https://irishrailwaymodeller.com/topic/8308-n-gauge-card-rolling-stock/ MikeO
- 55 replies
- 141 gauge n
- 141
(and 1 more)
Tagged with:
HI LostCarPark In N gauge card rolling stock is feasible but I am not aware of any where you can get an N Gauge kit which can be cut out and glueed together in the same way you do with Metacalf and other building kits. You can get OO gauge and larger card kits and scale them down. Also you can get diagram books such as those sold by the IRRS and scale them down. Wagons are usually fairly straight forward but coaches where windows need to be cut out to install glazing etc can be difficult, the small windows more so. Plenty of sharp blades, a good metal ruler and a fairly steady hand are required. Card can be a little flat and can benefit from such of plastic strips or wire as appropriate. Attached are a number of photos which hopefully illustrate the above comments First is a Wagon purely made from card and is a scaled down Alphagraphix OO gauge kit The second is a 6 wheel coach from Alphagraphix and scaled down The third is a wagon which started life a photograph and has been scaled and enhanced by vertical plastic strips The fourth shows how I made the body of the container from card although again plastic strips were used this time on the roof. That to me was easier then trying to cut card to a consistent width and length The last shows how such models can look well at normal viewing distance despite their appearance close up. The first container is that in photo 4 while the second container has been enhanced with plastic strips around the edge. With more care than in the first 3 photos card models can look very professional. But it does require a lot of patience and attention to detail. Another way to use card is to glue the required parts on to an existing donor model. The C Class loco in photo 5 shows what can be achieved. MikeO
- 19 replies
- 8
- rolling stock
- card
(and 1 more)
Tagged with:
Wexford Model Railway Club's Annual Exhibition 2020
MikeO replied to Irishrailwayman's topic in What's On?
Hi Gerry Sent you a pm MikeO- 20 replies
- 1
- model railway exhibition
- annual exhibition
- (and 2 more)
Thanks debrawenlock It was a great day with plenty of interaction with the public. Unfortunately I missed a lot of good layouts including yours. MikeO
Over the last 4 weeks the T Trak layout has made 3 appearances, Blackrock, Whitehead and La Mon Hotel. The following photos are a selection from each. Included in the Blackrock Section are some more photos of Ballyconnel Road. Unfortunately the T Trak photos do not have any trains apart from 1 Swedish railcar. T Trak Ballyconnel Road Whitehead At this show we were fortunate to be located inside the Directors Saloon (No 50). Include are some photos of other layouts located in the main train gallery. I did not get to see any others in the rest of the museum. The first two photos show the inside of the saloon. Next is a display of mostly Irish O gauge models The Portadown Layout which I think is under new owners is billed as a work in progress Two photos of this The Saltdean layout was also here I only got 2 photos La Mon Hotel I got a better selection of photos here MikeO
This question comes up now and again and the answer as BosKonay says there are not enough people interested in Irish N gauge to make RTR a profitable concern, hence the concentration on conversions and scratch building. Taking the membership of this form as an example, there are probably only about 5 people with a declared interest in Irish N gauge a very tiny percentage, under half of 1%, of the total membership of 1289.
Eoin That is disappointing but I suppose that is the vagaries of printing even on a professional level. Some time ago I got electragraphix sides for MK2 coaches where the "orange" had the same hue as the OO gauge coach in your photo but a got the same sides earlier this year and the "orange" was not too far off the shade on your Friday prints. MikeO
- 55 replies
- 1
- 141 gauge n
- 141
(and 1 more)
Tagged with:
Have not used velcro as I thought it would make the backscene sit too far out from the baseboard creating an unseemly gap. Magnets would be a better choice as they can be recessed into the baseboard and just require 2 thin pieces of metal (washers) glued to the backscene to make a good join. I have attached 3 photos to illustrate the concept. The first shows the 2 magnets in place, the second one of the washers, it can be partly covered, and the third shows how little gap there is. This is not my idea but a friend used on his T Trak module. Hope this is helpful MikeO
Mayner The One Track Minds layout looks very realistic a credit to the modellers skills. Your N gauge layout looks very well even though not fully complete. A lot can be put into a small width space where the length compensates for the lack of depth. I have a German layout in the loft which is being revamped but comprises, for much of its length, a width of around 34cm. While part of the track does run along the edge I have various amounts of track and scenery leading back from the edge towards the wall giving depth and hopefully a good degree of realism when finished. Attached are a couple of photos to show what I mean. Other parts of the layout are around 53cm in order to fit in the curves and the town area. MikeO
Divecontroller, wacky but I thought they were very well done with a good number of modules providing ideas that could be tweaked for European layouts. Mayner, realism is a challenge in N Gauge. Many small items are nearly impossible to make or buy and in the end may not even look right. ONe being a bigger scale makes it a little easier to get things to look right. the modules in the video are impressive and provide ideas that could be used in N gauge. I think also the longer sized modules helps to create a sense of space which adds considerably to the realism of the scenes being depicted. There appears to be no convention requiring the track to be a specific distance in from the front of the module as in T Trak. A number of the ONe modules have a good deal of space at the front which allows for making more realistic scenes. Each module therefore needs to be free standing which is more feasible with the longer lengths of the modules. MikeO
In order to answer David Holman's comment in my T Trak thread I thought I would start a new topic. While the issue is T Trak modules none are Irish themed so I did not want to mix it up with Irish themes. The Peco module is very good and shows how a module can be developed in ways different to the more traditional style in my layout. The Kato contest was held in July and attracted a wide variety of styles of module themes; most were naturally Japanese orientated. As it was a contest the result was that each was a mini stand alone style diorama where the contestants gave free rein to their creative side. That said the detail was superb with lots of inspiration . For those interested this is the link to I think the results page. Lots of pictures and minimum text. https://www.t-trak.jp/blank?lightbox=dataItem-k0ywxduh7me MikeO
Tony Thanks for the comments. I do remember that incident. Did not know that was you. N gauge has a lot of possibilities and lots of RTR but not for Irish but I think the effort is rewarding MikeO
Eoin Good news. Would there be any chance of seeing a sample at Blackrock next month. MikeO
- 55 replies
- 1
- 141 gauge n
- 141
(and 1 more)
Tagged with:
