Everything posted by GNRi1959
Ernie, Thanks for that. I wanted to be sure
Thanks, I was pleased with the appearance despite its very random application. Indeed, that I have noticed
Am I right to say that slaters plasticard skating sheets are cut into strips before applying?
Amazing detail in every form
The local press are coming next week!
Took a step back today and primed the entire build with Halfords grey primer. The enamels were not taking to the plasticard very well.
Thanks David, The overall footprint is around 1200 x 550mm and this was taken from the original Dundalk engineers drawings. As stated earlier, some alterations were made to the roof when the height was greatly reduced in 1955. Over the years some arch openings along the side were built up with stone from the reducing work in an attempt to secure the building. The huge sheeted doors were pulled at night to close the rear and front access to the store interior. It will make for a small shunting project but I believe, with only 2.8metres aavailable in total it will lend more towards a diorama than actual layout. It has generated much interested locally from the few surviving GNRi staff in town. This pleases me more than anything.
Lorries reversed into the Goods yard through various entrances. This one was one of a couple that Scott's Mill used to pick up bags of loose grain.
David, very helpful tips there. Do you recommend acrylic or oil based enamels?
This is a very nice example, Thanks for posting. My plan was to run a light grey into the joints and pick out the individual stones with various shades as illustrated in the picture I took of the original store below. Although this one is b&w, I did take many colour shots too.
Broithe, this is all pre-paint. Will be grey in the end.
If he was taking it to the North Cabin he is running in the right direction though he would have to cross the platform across the timber catwalk, end if platform
I need guttering and downpipes for my Goods Store. It would be industrial sized material, the prototype was quite large, almost box section. Any clues?
Today, ex-GNRi carpenter Billy Caldwell called to check out my model of the Goods store. He talked in detail of how he worked with a squad of tradesmen 1954-55 to lower the entire roof of the building. He gave me a commentary of the 'goings on' inside when Omagh was a busy mainline station. According to Billy, the model is very exact!
Tomorrow, the Carpenter at Omagh GNRi station Is calling to check the finer detail of this build with me. He repaired many of the sheeted doors in the Goods store and repaired the roof many times. He went on to work as Clerk of Works with the lifting train squads at Omagh.
Something worth noting if you are planning on using Wills Red Brick headers over arches. Although Omagh had three brick headers over all arch openings, Wills brick headers appear to be over-sized and look out of place. Acting quickly before my adhesive totally set, I removed these headers and reduced them to two brick headers, as can be seen below.
- 324 replies
- 12
Thanks Patrick, really enjoying this build. It's a modular 3 piece build. Today I primed the roof as I want to start some work on this early next week. What's the best finish available for corrugated asbestos roof? Is Slaters too thin or is Wills better thickness?
The really sad thing is that every hour, of every day, of every week Bus no. 273 leaves Belfast via Dungannon and Omagh to Derry and every hour, of every day, of every week another bus leaves Derry on the same route to Belfast. Every Sunday evening five double decker buses packed with students leave Omagh alone for Belfast.
