Everything posted by GNRi1959
Broithe, this is all pre-paint. Will be grey in the end.
If he was taking it to the North Cabin he is running in the right direction though he would have to cross the platform across the timber catwalk, end if platform
I need guttering and downpipes for my Goods Store. It would be industrial sized material, the prototype was quite large, almost box section. Any clues?
Today, ex-GNRi carpenter Billy Caldwell called to check out my model of the Goods store. He talked in detail of how he worked with a squad of tradesmen 1954-55 to lower the entire roof of the building. He gave me a commentary of the 'goings on' inside when Omagh was a busy mainline station. According to Billy, the model is very exact!
Tomorrow, the Carpenter at Omagh GNRi station Is calling to check the finer detail of this build with me. He repaired many of the sheeted doors in the Goods store and repaired the roof many times. He went on to work as Clerk of Works with the lifting train squads at Omagh.
Something worth noting if you are planning on using Wills Red Brick headers over arches. Although Omagh had three brick headers over all arch openings, Wills brick headers appear to be over-sized and look out of place. Acting quickly before my adhesive totally set, I removed these headers and reduced them to two brick headers, as can be seen below.
- 324 replies
- 12
Thanks Patrick, really enjoying this build. It's a modular 3 piece build. Today I primed the roof as I want to start some work on this early next week. What's the best finish available for corrugated asbestos roof? Is Slaters too thin or is Wills better thickness?
The really sad thing is that every hour, of every day, of every week Bus no. 273 leaves Belfast via Dungannon and Omagh to Derry and every hour, of every day, of every week another bus leaves Derry on the same route to Belfast. Every Sunday evening five double decker buses packed with students leave Omagh alone for Belfast.
Thanks Banntry, something l picked up from my fellow modellers on this forum, probably David Holman, genius of our time. And progress continues today.....
Jason, thanks. It's a slow process as I have so many factors to consider. The use of a scroll saw really helps.
More stonework in place today, switched from UHU glue to Evostik impact adhesive and got better bond, thanks to Warbs advice.
Started covering my goods store with Wills Scenic Sheets, going well and disguising any of my joints with Das modelling clay
David, I am referring to the built blockwork to the left.
A section of Omagh Goods Store was built with block on the flat, which measures 440mm x 105mm. Any ideas on what I could use in Plasticard? In 4mm scale this would be approx 6mm x 1.5mm...... is 7mm scale brickwork close?
Called into 'The Station Centre' yesterday and photographed the rear of the Goods Store that remains and took some pics to get detail of colour and finish.
Initial plans to use DAS modelling clay have changed last minute after buying a pack and using it on a scrap of ply. I've settled for Slaters Random stone as i don't want to learn a new skill, I've plenty of experience with plasticard.
Goods Yard Store now complete and glued up. It comes together in three sections that connect on the baseboard top. Ready for final finish in the coming days.
When your grand daughter invites you to nursery for their 'stay and play' programme it's not hard to get creative with coloured paper, scissors and PVA.
Going up to the rear walls of the Goods Store that still remain to photograph the stone detail and get some idea of colour........
Jason, I really didn't mean it, the way it came out. Of course it would work but this building is really big, and this would involve a lot of scribing. I don't know if I would have the patience and certainly not the eyesight at close quarter. I might just order some and try a bit on scrap ply. PS. Just ordered some to try
