Mike 84C Posted April 15, 2022 Posted April 15, 2022 Three signals for Bantry. All done from a drawing in New Irish Lines and various photographs of the prototype Bantry station so there is a bit of guestimation in some of the heights and details. They are powered by servos under the baseboard controlled by a GF controls dual servo control unit. I took all the advice and pointers I could get from Steve Hewitt on RMW , he builds excellent working signals and freely gives help and advice. The finials are Scottish one's The arms are L&Y as are the weights Cast lamps are Midland/GCR The ladders and all the above are from MSE/Wizard Models Posts, wires for handrails are things I had in stock plus those handy little bits of saved etches. 11 6
Galteemore Posted April 15, 2022 Posted April 15, 2022 Seriously impressive. Adds massively to atmosphere and effect. 1
David Holman Posted April 16, 2022 Posted April 16, 2022 Great work, Mike. Signals are such delicate, fiddly things to build, but so worthwhile when done as well as this. 1
Angus Posted April 16, 2022 Posted April 16, 2022 I like those Courtney and Stephens posts you've modelled, quintessentially Irish! Could I twist your arm to share how you did them? They are a lovely set of signals. 2
Mike 84C Posted April 16, 2022 Author Posted April 16, 2022 Angus, I worked from a drawing in New Irish Lines for Nov 19 which is 7mm to the ft, I believe its a David Chown drawing. But the article says it could be 8mm/ft! So I used my judgement to get a visual balance. The distinctive "cricket bat " shape I marked up out on N/S sheet, drilled holes then opened them up to form the slots, did the profile of the "bat" with files and soldered 1'5/2mm N/S etch offcuts around the edge of the "bat" I did'nt put the little cross pieces on the "bat" ,that was one step beyond for me! Hope that helps. And thank you for your comments. 2 1
