Liam_Murph Posted June 7, 2023 Posted June 7, 2023 Has anybody experience with using magnetic couplings like accurascale magnetic chain couplings or the selection of couplings from glr? If so which are most functional/easy to use or are they not worth the effort of changing? Quote
Past-Avenue Posted June 15, 2024 Posted June 15, 2024 Hi I use alot of IRMs Magnetic Dellner Couplings on my wagons and the 42ft flats. I found that they work great on the Inclines etc. You can see some in the link below. https://youtube.com/@endabyrne3420?si=g6jzJNtCx34pPn6F Enda Quote
Noel Posted June 15, 2024 Posted June 15, 2024 (edited) Unfortunately/Fortunatley I cannot use magnetic couplings, because to operate I need to be able to uncouple wagons and rakes of coaches and shunt stock on the model layout. I moved our rolling stock over to Kadee's some years ago and have nearly completed the transition away from TLCs. Kadee's enable automatic uncoupling and delayed uncoupling that is impossible with magnetic couplings without the 'hand of god' from the great layout sky manhandling stock on the tracks. At least magnetic couplings are orders of magnitude easier to live with, than tension lock couplings and no slop along ranks of coaches and wagons. Edited June 15, 2024 by Noel Quote
Georgeconna Posted June 15, 2024 Posted June 15, 2024 For Kaydee Fans Enniskillen Model shop have them on the shelves there. when I talked to the lads they said call and they will post no bother, No customs fees. £10.75 a pack. Modellers Corner Quote
irishthump Posted June 16, 2024 Posted June 16, 2024 (edited) On a whim I bought some of the Hornby magnetic couplings last week and I’ve been experimenting with them. I already fitted them to a rake of the cheap MK1 coaches that came with the My Model Railway Village magazine a few years ago. They’re a little too short for those coaches and need to be glued in part way on the NEM pockets. But one fitted they work fine. I then tried them on the IRM ferts and they seem fine. The coupling bar that IRM provide with the wagons works fine, but I wanted to be able to break the rake down easily for storage. The 17mm Hornby couplers are the perfect size. Edited June 16, 2024 by irishthump 5 Quote
