Moogie-69 Posted November 7 Posted November 7 (edited) This one is definitely a GNRi bogie wagon. Edited 7 hours ago by Moogie-69 3
popeye Posted November 7 Posted November 7 Just built one and almost painted. The RPSI Whitehead photo's were a big help. It did get changes to it over it's life. 1
Moogie-69 Posted November 7 Author Posted November 7 50 minutes ago, popeye said: Just built one and almost painted. The RPSI Whitehead photo's were a big help. It did get changes to it over it's life. Noticed that the old pictures of it had grain doors and when renovated they were omitted. 2
jhb171achill Posted November 7 Posted November 7 (edited) 1 hour ago, popeye said: Just built one and almost painted. The RPSI Whitehead photo's were a big help. It did get changes to it over it's life. I think there were several variants too. Edited November 7 by jhb171achill 1
Mol_PMB Posted November 8 Posted November 8 11 hours ago, Moogie-69 said: This one is definitely a GNRi bogie wagon. Very nice! 10 hours ago, Moogie-69 said: Noticed that the old pictures of it had grain doors and when renovated they were omitted. The RPSI description explains the conversions in detail. The surviving one has been restored to show elements of both the cask and grain versions. https://www.steamtrainsireland.com/rpsi-collection/52/504-guinness-grain-van I think I have some photos of it from my visit to Whitehead a couple of years ago. It is in the museum and is easily accessible on one side - and inside too.
Moogie-69 Posted November 9 Author Posted November 9 First print turned out almost perfect except for the small vents but that can be repaired. 6
Mol_PMB Posted November 10 Posted November 10 That looks great! Any thoughts on doing the grain version?
Moogie-69 Posted November 10 Author Posted November 10 6 hours ago, Mol_PMB said: That looks great! Any thoughts on doing the grain version? Should be able to do that, only need to delete a set of doors, add a ladder and grain doors. 2
Mol_PMB Posted November 10 Posted November 10 24 minutes ago, Moogie-69 said: Should be able to do that, only need to delete a set of doors, add a ladder and grain doors. Thanks! I could add one to my grain train.
Moogie-69 Posted November 10 Author Posted November 10 6 hours ago, Mol_PMB said: Thanks! I could add one to my grain train. Would something like that do you ? Couldn't get a good photo of the roof hatches, so they could be a bit off. 2
Mol_PMB Posted November 11 Posted November 11 20 hours ago, Moogie-69 said: Would something like that do you ? Couldn't get a good photo of the roof hatches, so they could be a bit off. That looks great - thanks. I think it represents them in early preservation condition though, the doors on one side were added by the RPSI. When they were in service, both sides were like the upper image - these two photos show opposite sides (note the brake lever orientation): Is that an easy fix? Many thanks, Paul 1
Moogie-69 Posted November 11 Author Posted November 11 Yep, easy to sort out. Do the brake levers both point in the same direction ? 1
Mol_PMB Posted November 11 Posted November 11 1 minute ago, Moogie-69 said: Yep, easy to sort out. Do the brake levers both point in the same direction ? Yes, only one bogie was braked. Both brake levers point towards the unbraked end of the wagon. 1
Moogie-69 Posted 17 hours ago Author Posted 17 hours ago Just the brake levers to add and that will be the grain van complete. 1 3
Mol_PMB Posted 14 hours ago Posted 14 hours ago That looks very good! Amazing detail in the print which has come out very well. Being very picky (sorry) There were small grab handles on the roof at the top of the ladders, easily added with a bit of wire. Maybe mark the hole positions with dimples? Also above the bogies, there were oval holes/recesses in the solebar with rivets around, where the bolster was attached. Not sure if those can be incorporated in the print? Again, they could be drilled/added afterwards. The roof hatches look a bit ‘heavy’ (too tall) to my eyes but I appreciate there aren’t many good photos of the roof. I think the tall bit on the diagram is a rib along the middle, the actual plate of the hatch is lower. Look at the pics and end elevation on the diagram. I hope this is constructive. Enda will tell you I’m just as picky with him, because this only has to be got right once on the drawing and will then be duplicated many times… Great work! 3
Moogie-69 Posted 7 hours ago Author Posted 7 hours ago 5 hours ago, Mol_PMB said: That looks very good! Amazing detail in the print which has come out very well. Being very picky (sorry) There were small grab handles on the roof at the top of the ladders, easily added with a bit of wire. Maybe mark the hole positions with dimples? Also above the bogies, there were oval holes/recesses in the solebar with rivets around, where the bolster was attached. Not sure if those can be incorporated in the print? Again, they could be drilled/added afterwards. The roof hatches look a bit ‘heavy’ (too tall) to my eyes but I appreciate there aren’t many good photos of the roof. I think the tall bit on the diagram is a rib along the middle, the actual plate of the hatch is lower. Look at the pics and end elevation on the diagram. I hope this is constructive. Enda will tell you I’m just as picky with him, because this only has to be got right once on the drawing and will then be duplicated many times… Great work! Most of that is an easy fix, I don't mind the criticism, with no clear photos of a roof I have to try and draw what I think I see on the drawings. As you see I don't always get it right, that's everyone else's job that has more knowledge of these things than me. Roof hatches - is 1 the upstand/ collar on the roof and 2 the smaller cap ? 3 is a single strap to hold the hatch on ? What do you think the 2'0" x 1'6" refers to, surly the hatches would have been square ? I'll update shortly. 1
Mol_PMB Posted 3 hours ago Posted 3 hours ago Sorry for taking ages to respond - really busy and away from home today. Yes, your diagram and numbering of the hatch parts looks right to me. I think that the 2’ x 1’6” is the size of the hole in the roof. 2’ along the length of the wagon and 1’6” across the width. The hatch would be maybe an inch bigger all round. They would have been rectangular. The black thing here is a hatch: Hope that helps! Some other grain wagons had round hatches but not these ones. Here’s a closeup of the solebar detail above the bogies, with the oval hole and rivet pattern. Also a hook for horse shunting on the left: Thanks again! Mol 2
Moogie-69 Posted 2 hours ago Author Posted 2 hours ago (edited) @Mol_PMB Less chunky roof hatches , bogie and frame details. Just need to get the brakes sorted now. Edited 2 hours ago by Moogie-69 2 1
Moogie-69 Posted 41 minutes ago Author Posted 41 minutes ago Brakes attached, they sort of represent what's on the real thing. 1
Mol_PMB Posted 25 minutes ago Posted 25 minutes ago 13 minutes ago, Moogie-69 said: Brakes attached, they sort of represent what's on the real thing. Those brakes look pretty good based on the photos on the RPSI page. Only on that bogie, the other end without. Some rivets on the hornguides either side of the axleboxes?
