Irish Wagon Sheets (Tarpaulins)
I'm planning to add a couple of sheeted wagons to my fleet, so I've been doing a bit of research on wagon sheets, which I thought I'd share here.
I'll start with the traditional tarred canvas sheets, and later posts will consider more modern plastic sheets.
There's a good general introduction to the subject here - from a GB perspective but much of this is likely to be applicable to Ireland too.
https://igg.org.uk/rail/9-loads/9-tarps.htm
It's interesting to see the different layouts of lettering and coloured stripes used by the different companies. Typically the company name and the sheet number were repeated in several places, and the sheets also carried a date, with a date of manufacture and/or a date when it would fall due to be refurbished.
This is a reproduction of an article from the LMS magazine of 1925 which is more of a primary source, and gives some information on the lifetime and markings:
https://www.lmssociety.org.uk/topics/sheetDepartment.php
From 1919 all new sheets were standardised by the RCH at 21ft x 14ft 4ins, and it's reasonable to assume that this sheet size was also adopted in Ireland.
Wagon sheets were primarily intended for covering an entire open wagon including its load, to protect the load from the weather and to secure lightweight or loose items.
A nice view of some CIE sheets is here: https://catalogue.nli.ie/Record/vtls000305343
Very bulky loads might require two sheets.
However, sheets could also be used in other ways, for example to cover a van with a leaky roof, such as the first one in this train from Ernie's collection:
Ballina J19 on stub of Killala branch early 1950's
Again from Ernie, this view shows (above the loco cab) two open wagons with sheets used to protect a load within a wagon, rather than spread over the entire wagon:
MGW Dublin North Wall 184poss early 1950 s
If the load doesn't fill a sheeted wagon, then the sheet will tend to sag in the middle and rainwater will pool in it. This is undesirable and can lead to leakage of a worn sheet.
Some early wagons had curved ends to support a sheet in a way that rain would naturally run off it. In GB some wagons had a 'sheet rail' or 'sheet supporter' which provided a ridge pole along the length of the wagon, so that the sheet would rest in a tent shape. This was less common in Ireland but a few wagons were fitted with brackets for sheet rails. Here's one, though the rail itself isn't fitted https://catalogue.nli.ie/Record/vtls000306419
More on the sheets themselves in the next post...
Wagons with curved ends were almost unknown in Ireland, as were the triangular-ended ones, like British "Saxa Salt" wagons. However there were a few. The CDR had at least one wagon with triangular ends - I've a (poor!) pic of it that my dad took of it in 1937. One of the West Cork narrow gauge lines - I think Schull, but it might have been Muskerry - had wagons with curved ends, as did the CBSCR. But "normal"-ended wagons, as shown in all those pics, were very much the norm.
My own recollections of "railway" tarps are few, but of distinctly worn things, often with a number on them (though pics show the older companies using initials, like "M G W R" or "G S W R", or "G N"). Dark grey or probably black when new. In the 1970s modern plastic sheet of any colour under the sun could be seen.
The NLI has several nice views of a train of sheeted wagons, some close enough to show the markings clearly. I included one in the previous post; here are the other two images:
https://catalogue.nli.ie/Record/vtls000305340
https://catalogue.nli.ie/Record/vtls000305344
There's also a nice sequence of photos of J15 116 at Waterford shunting sheeted wagons, some of which are in Ernie's collection:
1955-04-12 Waterford 116 HC img350 CIE 1955-04-12 Waterford yard 116.  RMC26018 RMC 83187
This is the same loco and wagon on the same occasion, but I haven't seen this shot in Ernie's collection:
Another sheeted open wagon can be seen in this image:
https://www.thetransportlibrary.co.uk/-/galleries/rail/lens-of-sutton-association/lens-of-sutton-association-irish-railways-part-2/-/medias/bafd2f8f-5a00-4f81-9f7a-8e02b58462af-cie-62-ex-gs-wr-d14-4-4-0-on-1-14-pm-to-mallow-in-sdgs-at-limer
This view of a wagon sheet used to cover something on the ground at Limerick is useful because it shows the C.I.E. lettering that would normally be on the top of the wagon and not so visible from the side:
Finally, there were some photos taken at Askeaton on the 1964 railtour that show an open container with a sheet on it. Roger Joanes photographed in monochrome:
Askeaton. 186 & railtour for Foynes. 7.6.64
But Norman McAdams had colour film for these three shots...
https://www.flickr.com/photos/irishrailwayarchive/54419501956
https://www.flickr.com/photos/irishrailwayarchive/54419695864
https://www.flickr.com/photos/irishrailwayarchive/54419501966
...and they show something that would be very hard to identify on a monochrome photo - two dark red stripes:
Coloured stripes weren't unusual on a wagon sheet, as those who have read the links in my previous post will know.
Based on these photos and using the standard dimensions, I've had a go at drawing a CIE wagon sheet from around 1960. The sheet number is shown in the middle of each side, and diagonally on each corner. The year of manufacture and the month it is due for refurbishment are marked on the lower side. The Gaelic-style CIE lettering is above the main numbers, and the two red stripes run the length of the sheet:
This version shows the location of the roping eyes by green spots, and the size of two open wagon types indicated by the blue and cyan rectangles. By comparison with how much of the sheet overlaps the sides and ends in the photos, I think the dimensions and layout are about right:image.thumb.png.37fe6656917c0ecdb147975d9ec16e98.png
No doubt there would be some variations in the lettering style and layout, and of course every sheet had an individual number.
For those into the GNR and with IRRS membership, here's a lovely colour shot of two sheeted GNR wagons - possibly biscuit containers under the sheets?
https://www.flickr.com/photos/irishrailwayarchive/53511470493
And further north, these two shots in Ernie's collection show containers covered with British Railways wagon sheets. The BR lettering and the style of date (shown like a fraction) are distinctive:
208 UTA 1956-06-07 Derry, Waterside 87 coprint208 209 UTA 1956-06-07 Derry Waterside 87 coprint209
The CBSCR had some open grain wagons with curved ends and a tarp rail like you describe. There's a good picture of one on page 125 of Cork Bandon & South Coast Railway by Ernie Shepard.
20 such wagons were bought by the CBSCR in 1904, although the book only states "at least one" had curved ends and a tarp rail. I have no idea how long they survived in traffic in that state.
Don’t think they lasted into CIE times, or at least very long into them IMG_8367.jpeg.4795b4e66e3276eba4feb086077abe2e.jpeg
Lovely picture! I guess the book can be updated to "at least five"!
  • Agree 1
'Irish Railways Today' (Pender & Richards, 1967) in describing the earlier wooden-bodied CIE-built open wagons, say:
"The batch 11987-12036 were similar and had hoops fitted for fertiliser traffic although this feature has been removed from most of these wagons."
My reading of this is that they had some form of sheet support rail, and it may be that the one I showed earlier is from this batch, albeit with the sheet rail removed although the brackets remain:image.thumb.png.22d83f4c5bcc0b6bcd4cb8506bed4ee3.png
Wagon 11987 of this batch is shown in 'Irish Traction in Colour' (Huntriss) page 83, but the angle of the view isn't helpful for sheet rail spotting.
