Noel Posted November 7, 2014 Posted November 7, 2014 Hi Folks Just wondering what forum members preferred choice of decoders is for MM locos? (for non sound use) 21 pin - Lenz, Bachmann, Zimo, LokPilot, other brands??? And which models of decoder. Thanks Noel
0 Irishrailwayman Posted November 8, 2014 Posted November 8, 2014 I have found ESU Lokpilot to be a pretty advanced chip particularly for double-heading 141/181/121s. The CVs are easy to adjust which may be necessary to get all functions working on the 201s which have unusual electronic set-up/architecture.
0 Dave Posted November 8, 2014 Posted November 8, 2014 If your after a budget decoder Hattons do their own one Single decoder http://www.ehattons.com/71920/Hattons_Model_Railways_Ltd_DCR_21PIN_Direct_21_pin_4_function_1_1Amp_direct_plug_decoder_with_back_EMF/StockDetail.aspx 5 Pack http://www.ehattons.com/71920/Hattons_Model_Railways_Ltd_DCR_21PIN_Direct_Box_of_5_21_pin_4_function_1_1Amp_direct_plug_decoder_with_back_EMF/StockDetail.aspx 10 Pack http://www.ehattons.com/71920/Hattons_Model_Railways_Ltd_DCR_21PIN_Direct_Box_of_10_21_pin_4_function_1_1Amp_direct_plug_decoder_with_back_EMF/StockDetail.aspx
0 Noel Posted November 8, 2014 Author Posted November 8, 2014 I have found ESU Lokpilot to be a pretty advanced chip particularly for double-heading 141/181/121s. The CVs are easy to adjust which may be necessary to get all functions working on the 201s which have unusual electronic set-up/architecture. Thanks IRM If your after a budget decoder Hattons do their own one Single decoder http://www.ehattons.com/71920/Hattons_Model_Railways_Ltd_DCR_21PIN_Direct_21_pin_4_function_1_1Amp_direct_plug_decoder_with_back_EMF/StockDetail.aspx 5 Pack http://www.ehattons.com/71920/Hattons_Model_Railways_Ltd_DCR_21PIN_Direct_Box_of_5_21_pin_4_function_1_1Amp_direct_plug_decoder_with_back_EMF/StockDetail.aspx 10 Pack http://www.ehattons.com/71920/Hattons_Model_Railways_Ltd_DCR_21PIN_Direct_Box_of_10_21_pin_4_function_1_1Amp_direct_plug_decoder_with_back_EMF/StockDetail.aspx Thanks Dave. I'm after folks preferred choice based on their usage experience. So are these the ones you prefer to use?
0 DiveController Posted November 8, 2014 Posted November 8, 2014 I have found ESU Lokpilot to be a pretty advanced chip particularly for double-heading 141/181/121s. The CVs are easy to adjust which may be necessary to get all functions working on the 201s which have unusual electronic set-up/architecture. Think Noel is not into 201s but that's good to know as I also have a rake of 141/181s that will need to be done and I intend to do some consists:)
0 Dave Posted November 8, 2014 Posted November 8, 2014 I found them very good, have them fitted in some 141's and the 8 pin ones in some of my American locos and no problems.
0 Noel Posted December 30, 2014 Author Posted December 30, 2014 I found them very good, have them fitted in some 141's and the 8 pin ones in some of my American locos and no problems. Hi Dave. I presume you mean the Hatton's ones. Do you know who's or which product they really are (i.e. rebadged)? I've now tried Lenz silver, Bachmann 36-557, Zimo MX644D and Bachmann 36-554 decoders in MM 141/181 locos. The cheaper Bachmann 36-554 does not seem to run these MM locos anywhere nears as well as the other three, and has a very strange power curve. The Lenz and Zimo seem by far the smoothest and quietest, especially at crawl. Its possible I'm not getting the best out of the cheaper Bachmann with its 'out of the box' settings. I've experimented with a few CVs but no significant change in behaviour. The Bachmann 36-557 is not bad at all though. Anybody else had success with various Bachmann decoders in MM141/181s?
0 Dave Posted December 30, 2014 Posted December 30, 2014 Hi Dave. I presume you mean the Hatton's ones. Do you know who's or which product they really are (i.e. rebadged)? I've now tried Lenz silver, Bachmann 36-557, Zimo MX644D and Bachmann 36-554 decoders in MM 141/181 locos. The cheaper Bachmann 36-554 does not seem to run these MM locos anywhere nears as well as the other three, and has a very strange power curve. The Lenz and Zimo seem by far the smoothest and quietest, especially at crawl. Its possible I'm not getting the best out of the cheaper Bachmann with its 'out of the box' settings. I've experimented with a few CVs but no significant change in behaviour. The Bachmann 36-557 is not bad at all though. Anybody else had success with various Bachmann decoders in MM141/181s? I'm not sure Noel who makes them for Hattons, but they work fine for me.
0 Noel Posted December 30, 2014 Author Posted December 30, 2014 I'm not sure Noel who makes them for Hattons, but they work fine for me. Thanks. I was a little disappointed with the older bachmann 36-554 as they were supposed to be better than the newer 36-557 which some hornby controller users had mixed results with.
0 Blu Bianco Posted January 2, 2015 Posted January 2, 2015 (edited) Thanks. I was a little disappointed with the older bachmann 36-554 as they were supposed to be better than the newer 36-557 which some hornby controller users had mixed results with. What have you heard about this Noel? Do you mind me asking what controller you use? I heard that Hornby Select users had issues with the 36-557's. However reading on some UK forums, there also appears to be people saying Hornby Elite users had issues with this decoder too. It is hard to know which of the 36-554 or the 36-557 is best to use if you have a Hornby Select, or if you have a Hornby Elite! Edited January 2, 2015 by Blu Bianco
0 irishthump Posted January 2, 2015 Posted January 2, 2015 What have you heard about this Noel? Do you mind me asking what controller you use? I heard that Hornby Select users had issues with the 36-557's. However reading on some UK forums, there also appears to be people saying Hornby Elite users had issues with this decoder too. It is hard to know which of the 36-554 or the 36-557 is best to use if you have a Hornby Select, or if you have a Hornby Elite! Well the Select is not NMRA compliant, so it has issues with several brands of decoders; Bachmann and TCS were the ones which caused the most hassle. The problem is with the Select itself, not with the decoders.
0 Blu Bianco Posted January 2, 2015 Posted January 2, 2015 Well the Select is not NMRA compliant, so it has issues with several brands of decoders; Bachmann and TCS were the ones which caused the most hassle. The problem is with the Select itself, not with the decoders. Thanks for that. You would expect then the Elite to be ok with both? Oh and a heads-up for anyone with an Elite who is thinking of getting one of Hattons own 21-pin decoders for their Murphy Models 141/18 loco, Hattons state on the product page that this decoder isn't compatible with the Hornby Elite.
0 irishthump Posted January 2, 2015 Posted January 2, 2015 Thanks for that. You would expect then the Elite to be ok with both? Oh and a heads-up for anyone with an Elite who is thinking of getting one of Hattons own 21-pin decoders for their Murphy Models 141/18 loco, Hattons state on the product page that this decoder isn't compatible with the Hornby Elite. To be honest I would expect the Elite to work with any decoder as Hornby state that it's NMRA compliant. If that's not the case then I would steer clear of it.
0 Barl Posted April 21, 2015 Posted April 21, 2015 To be honest I would expect the Elite to work with any decoder as Hornby state that it's NMRA compliant. If that's not the case then I would steer clear of it. Sorry to resurrect an old thread but I was just wondering if anyone knows what the issues are with the Elite and Hattons decoders? I have a few 201's and 071's to fit decoders to and I was thinking of trying these decoders (I can live with the lack of cab lights) but I'm also currently using the Hornby Elite controller. Is there a similar alternative that people on here have experience with?
Noel
Hi Folks
Thanks
Noel
14 answers to this question
