GNR 442t
Just discovered this grand old lady in my attic - made by a friend from a Studio Scale Models kit many moons ago. Des is going to send me suitable transfers but I was wondering what else I might need to do to get her going again? A far as I recall she was a solid runner but a bit noisy.......
4 answers to this question
Wow! That's a nice thing. Wasn't really aware of any many other steam kits from Des, certainly not this one. What chassis is under there? Also supplied by SSM? Some recent discussion on here about the length of time it takes a brass kit steamer to bed in, maybe 100 hours. Is there much mileage on the clock or it was sequestered in the attic before that occurred?
I suppose the first thing to do Patrick is to remove the body and see what type of motor is fitted. It's most likely a Mashima motor, is it not running at all? If not then test all the wiring is intact and put some power direct to the motor to see if it turns. It maybe a case of some light lubrication and running it on a rolling road for an hour or so. It that does not work then open heart surgery may be the only option.
Thanks folks - I currently don't have a line to run it on so I will probably bring it to a friend's layout to see if she has any life in her! Thanks for the advice - I have ordered the correct transfers from Des so if I can't get her going immediately, at least she'll be cosmetically restored!
Answer this question...
