pauldelany Posted April 20, 2016 Posted April 20, 2016 GOOD MORNING GENTS ,NEW TO THE FORUM ,ANYONE ADVICE ON CONVERTING AN Airfix BR 4F 0-6-0 TO DCC
WRENNEIRE Posted April 20, 2016 Posted April 20, 2016 Nice touch Skinner, try reading it again, NEW TO FORUM, doh
Railway Lyons Posted April 20, 2016 Posted April 20, 2016 He is trying to be heard over the rest of us..... Â @Paul, I have completed one before, same version if there is a permanent link to the tender, it was 10+ years ago, so below is from memory. The conversion needs to be carried out in the tender, easiest done with a chip with a wiring loom attached, how i did it. In the tender, feeds from loco end goes to black/red on chip, then orange/grey to the motor in the tender. Remove the capacitor between the motor contacts if there is one still there. Test run to ensure forward is forward, if not reverse wires going to motor. Â That should be the job done. Hope it helps.
pauldelany Posted April 21, 2016 Author Posted April 21, 2016 hi there cheers for that,did you change the look of the loco itself
Railway Lyons Posted April 21, 2016 Posted April 21, 2016 Hi Paul, Â I didn't changed the loco at the time. However, it is now on a long list of locos to have detailing added and possible conversion to Irish from its current LMS guise. Â Regards.
jhb171achill Posted April 21, 2016 Posted April 21, 2016 The most obvious thing if converting most British types to look even vaguely Irish can often be the cab. GSR loco cabs were usually unmistakeably Inchicore designed, while the GNR had a very identifiable style of their own. The NCC was a bit more of a mixed bag. Different if you're converting to be an actual Irish prototype; drawings are then necessary and any amount of alteration might result.
