Northwest141 Posted August 10, 2016 Posted August 10, 2016 (edited) Having bought a Train Tech lighting board for a Cravens at a cost of £17.00 plus £3.00 postage i wondered if there was a cheaper way to go about lighting the cravens First off the Train Tech lighting is excellent { motion sensored } after 2 to 3 mins it switches itself off again when it is bumped or coupled the lighting comes back on so all in all a good product { be it a bit costly } 5 coaches = £85 plus postage i searched around on e bay and found the following 5 x lightboards for 11 euro shipped { 3 volt operated } same as Train tech then i came across the 3 volt holders for the batteries { the holders are fitted with an on/off switch } which is ideal so i opened up a cravens and fitted the light bar to the roof then soldered the wiring to the switch { holder } fitted the holder in the back of the cravens { then making the window hole slightly bigger in the back of the carrige i was able to fit the switch with a few dabs of super glue { as seen in the pics } simple to operate , i use a pen to turn on and off the switch . paint the white switch a dab of black , or put the red cover on and nothing is visible . works a treat , and cheap too Edited August 10, 2016 by Northwest141
irishmail Posted August 10, 2016 Posted August 10, 2016 That's a great tip, also handy that you can turn the lights on/off as needed.
BosKonay Posted August 10, 2016 Posted August 10, 2016 Very nice indeed - any pics of the resulting light level?
Northwest141 Posted August 10, 2016 Author Posted August 10, 2016 (edited) Sorry not set up for video here , but result is the same as Train tech { WARM WHITE } that one was the first one done . and i see by the pics i need to file down a bit of the window opening to make it flush but for a few euro , im ok with it so far when run in a rake with the Train tech fitted coach, there is no change in colour . here is the link to the train tech lighting http://train-tech.com/index.php/lighting/interior-coach-lighting with both the train tech , and this set up , the battery is enclosed in the carrige so the drawback is , when the battery is low , the carrige must be taken apart to replace it but they give a long life 5-7 hours Edited August 10, 2016 by Northwest141
DiveController Posted August 11, 2016 Posted August 11, 2016 with both the train tech , and this set up , the battery is enclosed in the carrige so the drawback is , when the battery is low , the carrige must be taken apart to replace it but they give a long life 5-7 hours That's a great tip. A ten-fold reduction in cost is definitely worth doing and makes equipping a couple of rakes affordable for the average modeler. DO you thin it is possible to route the wiring between the window, drill a tiny hole in the floor and hide the battery behind the 'battery boxes' under the chassis. Battery replacement would be infinitely easier
Northwest141 Posted August 11, 2016 Author Posted August 11, 2016 That's a great tip. A ten-fold reduction in cost is definitely worth doing and makes equipping a couple of rakes affordable for the average modeler. DO you thin it is possible to route the wiring between the window, drill a tiny hole in the floor and hide the battery behind the 'battery boxes' under the chassis. Battery replacement would be infinitely easier Hi that was my original plan but sadly the holder is visible if mounted underneath it fits just perfect in the back compartment in the cravens next attempt will be a MK11 and see how that works out
irishthump Posted August 11, 2016 Posted August 11, 2016 Great tip! Can you post a link to the sellers on Ebay?
DiveController Posted October 8, 2016 Posted October 8, 2016 Great tip! Can you post a link to the sellers on Ebay? One ping only
DiveController Posted October 9, 2016 Posted October 9, 2016 Captain Ramius? A ping is as good as a bump, and it is October
Glenderg Posted October 9, 2016 Posted October 9, 2016 A ping is as good as a bump, and it is October You will get the Order of Lenin for this.....
