PorkyP Posted June 29, 2019 Posted June 29, 2019 Has anyone built any of the Alphagraphix card kits?... Are they any good? ..I'm assuming they need a fair bit of modification, with detail parts adding to look convincing especially in 7mm scale. I thought one would make a good starting point though, and they even do a station on the C&L which is my particular interest.. Any advice or info on building these kits would be much appreciated..! Quote
Galteemore Posted June 29, 2019 Posted June 29, 2019 (edited) I’m working on one of their rolling stock kits right now, using it as a drawing to cut out my own plastic parts. I will hopefully post the results later this week. They are a great starting point. Here’s my first Irish wagon which I made from an Alphagraphix card kit - what I would do if making it now is use the kit as a template for plasticard scratch building. But it got me started! Thoroughly recommended. Edited June 29, 2019 by Galteemore 4 Quote
PorkyP Posted June 29, 2019 Author Posted June 29, 2019 That looks great ! Love the battered look, right out of "the great squishing drama of 1959" !! Quote
Galteemore Posted June 29, 2019 Posted June 29, 2019 (edited) Thanks! A lot of the squishing was due to my mangling of the kit...hence my new technique of using plastic! But it was a good test bed for starting out in 36.75mm gauge...check out ‘Arigna Town’ for a master class in using these kits from someone who does know what they are doing! Edited June 29, 2019 by Galteemore Quote
PorkyP Posted June 29, 2019 Author Posted June 29, 2019 The squishing works though ! I'll try and find some of his wagons, you have to do some long winded thing of getting a catalogue thru the post or something I believe....? Quote
Galteemore Posted June 29, 2019 Posted June 29, 2019 That’s the business. I’ll post a list of what you might be interested in to get you started...o I should add that I was lucky enough to see his stall at a show. Here are some buildings he produced as samples..... 3 1 Quote
PorkyP Posted June 29, 2019 Author Posted June 29, 2019 Top man ! Thanks for that.... I'm assuming you've not tried doing a building ? 1 Quote
Galteemore Posted June 29, 2019 Posted June 29, 2019 Not as yet. I have actually built more of his brass stuff than card. But I have building kits in store.for my project David Holman, an esteemed member here, has employed them, using them as a pattern. His layout Belmullet is on here and shows what he has achieved. It’s impressive. Quote
PorkyP Posted June 29, 2019 Author Posted June 29, 2019 I'll have to search it out and see what he does with them, tho as you say he's using them as a pattern rather than make the kit itself. First off I'd probably just make the basic kit, (bit like you did with the wagon)..but maybe make more detailed windows etc, and perhaps the roof would need a bit more of a 3 D than flat card would give, and a bit of weather effect and such.. 1 Quote
Galteemore Posted June 29, 2019 Posted June 29, 2019 Good plan. The kits are cheap so even if you don’t make something you’re happy with it’s not a big issue! Quote
PorkyP Posted June 29, 2019 Author Posted June 29, 2019 And even if you wreck it, you've still got a template pattern to try again ! 1 Quote
Irishrailwayman Posted September 23, 2019 Posted September 23, 2019 I used more than 20 Alphagraphix kits for my "Ballybeg" layout in OO. The wagon kits work well too in this scale. 11 Quote
Galteemore Posted September 24, 2019 Posted September 24, 2019 Great work there. They totally identify the layout as Irish even if no rolling stock is visible. 1 Quote
PorkyP Posted September 24, 2019 Author Posted September 24, 2019 Brilliant stuff!..couldn't be anywhere else could it !.. 1 1 Quote
Irishrailwayman Posted November 20, 2019 Posted November 20, 2019 A couple of Alphagraphix card kits in 7mm built recently by John Walker of Wexford MRC and currently on display on the club's test tracks. Note the fully detailed interiours in the Signal Cabins: 8 Quote
Galteemore Posted November 20, 2019 Posted November 20, 2019 Nice work. I tend to maul Roger’s kits about so it’s nice to see some built as the maker intended! 1 Quote
Colin R Posted December 26, 2023 Posted December 26, 2023 A few weeks ago I had a reply from Roger about doing some new Irish based kits, if anyone has any ideas then please contact him. I do have a few of his kits which will make it on to a layout at some point. Colin 1 Quote
Irishrailwayman Posted March 14, 2024 Posted March 14, 2024 On 23/9/2019 at 8:15 PM, Irishrailwayman said: I used more than 20 Alphagraphix kits for my "Ballybeg" layout in OO. The wagon kits work well too in this scale. "Ballybeg" is booked for the Wexford Exhibition on 5th and 6th May 2024. It will be run in a "Modern Image" version featuring CIE "Supertrain" stock one day and Irish Rail "IR" rolling stock on the second day. 5 Quote
