Everything posted by Railway Lyons
Welcome back after the new year guys! There appears to be quite a bit of modelling going on in the last few weeks, so i thought I would put in my 2 cents worth. Currently on the bench are 2 ongoing conversions from Warley purchases. Hornby LMS 4MT for RPSI No.4 - (inspired by previous conversions seen on here) and Hornby S&DJR 2P for RPSI S Class "Slieve Guillon" - (something different) Progress pictures will follow in a few days once I get the camera back out. There is more on the bench awaiting completion, delayed due to lack of paint supplies etc. Here's to another year of good modelling and many more announcements.
Rapido Trains announce APT-E
Railway Lyons replied to Warbonnet's topic in British Outline Modelling
Hi Lads, Spoke to Jason from Rapido over in Warley, deliverys are expected to begin going out in January, fingers crossed. As for the HST announcement, all we could get from him is, "keep your eyes on the webpage". -
Wallacetown (Under new Management)
Railway Lyons replied to Railway Lyons's topic in Irish Model Layouts
Hi to all, Hope everyone has their Christmas lists sent off, and have been good to deserve them (but a sack of coal could come in handy for the steam engines) I have been away from the layout for a bit now, work commitments taking over. However, over the Christmas period, I have 30 point motors(SEEP) and 5 Accessory Decoders(MERG) to install to enable the eLink to run all from my PC. Once this lot is in, I will be doing up a proper running video(I haven't been happy with others so far). Best wishes to all for the coming season! -
Just spotted this lot on eBay: http://www.ebay.ie/itm/Murphy-Models-bachmann-lima-irish-livery-collection-/181879217042?hash=item2a58d89b92
Hi All, I have a couple of older tanker models at home that have seen better days. In an effort to try resurrect them, I got an idea to use them for part of the Weed Spray train. Their chassis are too far gone to save, but tanks could be put on donor flat to make up part of the consist. What I am wondering is, what is the diameter, in full or scale size, of the tanks on the Weed Spray? Many thanks for your help in advance.
Hi All, More updates from the workbench. As promised: NIR 3K, D301 & Restaurant. Extra to that is CIE MK1 and Mk3 DVT. Still a lot more to come in the next few weeks. Working on a running video also, so keep the eyes peeled.
Shed of the Year on Tv last night. Dream City in last 4 of the NORMAL category. Beaten to the post by a floating shed. Hard Luck Roy, was still amazing to see your work. You had mine and my girlfriends votes.
Lima 201 DCC conversion?
Railway Lyons replied to billyboy's question in DCC, Electrics and Electronics
Yes, I can see where the capacitor would come in handy for that. I have all live frog points and am not relying on the blades for contact. A bit of dirt on the contacts now could cause me trouble but i have always kept the Lima contacts as clean as possible. If I notice a decline in the future, I have the option to add the capacitor in any case. -
I don't have a capacitor built into the circuit for the lights. I have used the circuitry before and found it woks fine using the Hattons 8 PIN with Harness chips. -
I am doing something similar. I am fitting a LIMA 201 with DCC directional lights. Having ripped the motor and gears out, it will be towed/pushed on the end of my Push/Pull rake with motorised MK4 DVT. The newer motor in the DVT, from a Bachmann Voyager, has no problem moving 6 coaches and the dummy 201. It does look quite nice on the end of a rake. -
Hi All, Been a while since i have had the time to do any projects. Setting up the layout & shed has taken some of my time, and my daughter has got the rest of it. However, recently with the longer days, I have gotten out to the workshop and got modelling again. Here are my latest exploits: Mk4 DVT from a Pendolino - Still awaiting glazing and grills. Arrow from Class 158 Central DMU - doors and windows moved to get doorways in right place. Grey 071 from Orange/Black 082. IR Intercity from MK2 BR Blue/Grey More to come in the coming weeks! NIR 3000 CIE 4F CIE D301 IE MK3 Intercity and Restaurant...plus more
Hi JM, At a distance the lack of relief is not as noticeable, especially the better the print. What I have done in some instances before is added the print to an uneven surface to give it the effect of not being a wall paper. Or you can add some relief to it yourself by adding down pipes, air con fan units etc. You will be surprised how the eye can be tricked.
Hi Junctionmad, Most of my layout has it on it for walls, footpaths and building fascias. From my experience, a good printer set to high resolution will definitely give a good result. Just be wary of the fact that sometimes your screen resolution might show colours as desired, but print might have a slight different hue. Print a test and adjust as needed. Trial and Error can yield some interesting results.
Hi Burnthebox, A layout can be wired as DCC and operated as DC if only a DC controller is connected to the lines. However, isolating DC locos will not be possible due to the 'always live' aspects of DCC. Vice Versa is also in theory possible but as a DCC loco is isolated on a DC wired layout, you would would loose the lights/sounds etc. A DCC wired layout with a DCC Controller connected would make it all DCC. Once you loco chip is programmed, you are ready to go.
I personally have had no issues. I mailed asking regards postage for O and OO coaches, ordered at different times of the year. Amount was reasonable for each parcel and delivered in a timely fashion with no hassle to Rep. of Ireland.
First bit of running has taken place to check it is all working after travelling to my shed. All looks good, now to begin the computer control and detailing. -
Kedleston Terminus & Ballinea Junction
Railway Lyons replied to GSR 800's topic in Irish Model Layouts
Good Luck with your endeavors! Look forward to seeing your progress. -
Congratulations!
Well guys, been a few weeks but nearly there. Shed is up, insulated, floored & walled, power connected and heater added. Just need to finish the lighting. Layout is in but not running yet, still organizing the space (bikes etc to be removed). -
That is the idea, it occurred to me too. Few mods to signage etc and it could be easily adapted. I have enough stock to run either scene. I do hope at some stage to bring it back out into the exhibition scene and show off the full capabilities. -
Easier to seek forgiveness than permission. She is being suitably spoiled for Christmas, so I will not be banished to the shed once it is installed. Plenty of updates along the way. -
At the October MRSI exhibition in Raheny, UMRC had their layout Wallacetown for sale. I duly snapped it up, and then asked my better half for permission to bring it home, permission granted! A shed has now been ordered for it and this coming January, the layout will go through a transformation. It will become full DCC (track, lights and points) with a lot of detail added to the already existing layout. Below are some pics of the layout as it was at the Raheny show. I hope in the coming year to post up regular updates of my progress in bringing this well admired layout to the next stage. Here is to a successful year, Happy Christmas to all, and plenty of modelling.
One I spotted last night: http://www.ebay.ie/itm/141461658171?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Leinster Models B1A O Gauge http://www.ebay.ie/itm/221545073407?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Amazing work, would love to get my hands on a kit. Have a MK 1 on the workbench just asking for something to be done with it.
