Everything posted by Fiacra
Bushings! Now that I know what they're actually called, I can search for them - thanks Phil. Thanks for this info Brendan - will definitely check out the articles in New Irish Lines. It did occur to me that the hubs could be trimmed and glued in place, but that seems such a shame when they were designed to rotate. Alas, it might be the only option. Regarding the side-to-side play, it's probably not so pronounced with 21 mm as the wheels are pushed out close to the bogie frame, which (together with the glued hubs) would presumably limit the side-to-side movement? I'll have a look around for longer bushings, as suggested by Phil, but otherwise it might actually be easier to bypass the EM trials and go straight to 21 mm!
Having thought about the pros and cons of 21 mm a bit more, I've decided to have a go at constructing a short length of 21 mm track and a couple of points, just to see what it entails - and I'll convert a 121 to run on it. Before that though, I thought I would ease into the whole conversion experience by first converting the 121 to EM and running it on some Peco EM bullhead track and a couple of kit-built EM points. And so I've arrived at my first bump in the road....... The attached photo shows a bogie on the 121 with the left wheel set re-gauged to EM (on original axle), while the right wheel set has not yet been re-gauged. What I've noticed is that there is now quite a bit of side-to-side play in the re-gauged wheel set due to the increased space between the wheels and the brass(?) rings that hold the axle in the gear block. This isn't an issue on the 16.5 mm wheel set because the wheels are tighter to the brass rings and this limits the side-to-side movement. Brass rings (whatever they're actually called) with a longer cylinder would seem to be the obvious solution - or some type of spacer that can be put on the axle between the wheel and the brass ring. Does anybody know if such items are readily available? Another thing I noticed is that when the wheels are spaced for 21 mm gauge on the original axle, the outside face of the wheel is almost flush with the end of the axle. This leaves no room at the end of the axle for the rotating hubcap to slide on to it. Has anybody found a way around this? As always, thanks for any input!
Hi folks, Have any of you had problems ordering from C & L? I placed an order via their website in mid-September and got confirmation from my bank that the payment went through a couple of days later. However, my order status is still showing as 'awaiting payment/awaiting processing' on the C & L website. Have sent a couple of emails, but no response. My understanding is that C & L is a one-man operation, but still, this seems like an unusually long time. Anybody else had a similar experience?
Completely agree - very atmospheric!
Took a spin out to Maam Cross this morning for a better look - indeed it was the plough van that passed my window yesterday.
Only caught a quick glance as I went running to find my camera (but not quickly enough) - certainly similar to that though.
Was looking out the window of my house here in Oughterard (Co. Galway) a minute ago and, quite unexpectedly, saw a brake van on the back of truck pass by! Presumably on its way out to the crew at Maam Cross?
Thanks for that suggestion Andy. I wasn't aware of the MJT bogies, but just checked them out and they don't seem overly complicated to construct. I take your point on EM still not looking right - I suppose I would be settling for something that looks 'less wrong' than 16.5 mm. However, those bogies are now making me consider going P4 instead of EM, which would look less wrong again I know it might seem pointless to go to all the effort of P4 conversions rather than going to the full 21 mm, but the matter of pointwork construction for the latter still terrifies me!
Not at all Phil - grateful for all input on the matter! I think there are two main issues putting me off going the 21 mm route, despite the layout being solely Irish outline - pointwork and re-gauging rolling stock. The planned layout will have around 18 points in total (including the fiddle yard), and building all that from scratch seems quite daunting - not just the actually construction, but doing it to a standard that ensures reliable running. With EM or P4, there are ready-to-lay or easily assembled turnout kits available on the market. On the re-gauging side of things, my understanding is that converting to EM is, usually, fairly straight forward. Sometimes it's possible to re-space wheels on their existing axel, but failing that, drop-in wheel sets are readily available - perhaps needing only a slight sanding of the inner side of the bogie to create sufficient space. With P4 and 21 mm gauges, considerably more re-building of bogies is required to accommodate the wider wheel sets. I know this is not an issue with the Murphy Models and IRM locos, which were designed to accept 21 mm wheel sets, but that doesn't seem to be the case for the MM MkIID and Cravens that I've procured. That being said, if the new run of MkIID will have wider bogies ready to accept 21 mm wheel sets, that could have an influence on the matter. Similarly, if IRM have any new coaching stock announcements coming up, that might also help sway my opinion
Thank you all for your input. It seems that A or E get the most votes, which was probably to be expected. 'A' is Peco EM gauge code 75 bullhead flexitrack (available from EMGS) while 'E' is code 75 bullhead rail threaded on to Exactoscale FastTrack P4 bases. 'B' is SMP Scaleway 00 gauge code 75 bullhead flexitrack, 'C' is Peco code 75 bullhead flexitrack, and 'D' is code 75 bullhead rail threaded on to Exactoscale FastTrack 00 bases. I didn't include any 21 mm gauge as I've already ruled this out as an option - whereas EM and P4 are well catered for in terms of ready to lay (or almost ready to lay) plain track and pointwork, 21 mm would require everything to be built from scratch, and that feels like a step too far for me. Personally, I quite like the sleepers (spacing and thickness) on the Scaleway track ('B'). Having spent much of my youth hanging around the disused sidings of Liffey Junction during the 1980's (out of an interest in all things railway, not for any nefarious purposes - honest guv!), the Scaleway sleepers just look 'right' to me. I know some posters on the EMGS forum have pointed out that the Scaleway sleeper spacing is actually too close for prototypical British outline modelling, but perhaps there is/was a difference in sleeper spacing between Ireland and Britain? Scaleway also do an EM version of their flexitrack, and I think this is what I will go with. As David Holman pointed out above, the difference in gauge can be subtle, and a lot depends on the angle at which the track is being viewed, but I'm thinking EM is probably the best compromise for my purposes. Which leads to my next question; is there anybody out there modelling Irish railways in EM? Thanks again to all.
Hi folks, I came back to the hobby a couple of years ago after a 30 year absence (yikes - where did the time go?!) and I've finally started exploring ideas for a new layout. For me, a layout is all about capturing an atmosphere rather than aiming for prototypical perfection, so I'm not necessarily hung up on the finest of details. However, I think trackwork can have a huge influence on atmosphere, and I do want to spend some time on this aspect of things. The layout will be set in the early 1990's, so I can just about get away with using bullhead track - which I find the most visually pleasing. So, code 75, bullhead is what I plan to go with. The next matter is gauge. Obviously, the further one diverges from 16.5 mm, the better the track can look, but the whole thing becomes more technically challenging. So, my goal is to find the sweet spot between appearance and convenience. To that end, I've laid five pieces of track from assorted finescale suppliers and quickly ballasted them - photos attached. I would be very grateful for any opinions that board members might wish to offer as to which looks the most (or least) prototypical (again, stressing that atmosphere is my main objective). For now, all I'll say is that there is more than one gauge on display, and the sleepers come from more than one supplier. Also, I've painted all of the sleepers with the same flat brown, so as to remove colour from the equation. Thanks in advance for any input!
Brilliant - thanks a million!!
Thanks Galteemore - do you have a current email address for them?
Hi folks, Just wondering if anybody knows a way to order from Marcway Models other than by phone? Their website is rather basic and there are no obvious online ordering links (that I can see). Many thanks!
John, your trackwork is simply sublime - possibly the best I've ever seen on any layout. Any chance that you might find the time to post some instructional videos or tutorials explaining how you do it?
Ahhh, I see. Still, it's a beaut!
Many years ago, I had a go at converting a Royal Scot to Maedb, but it didn't turn out anywhere near as good as this. Stunning job!
Fiacra replied to Patrick Davey's topic in Irish Model Layouts
Wow, what an absolutely stunning layout!! -
Fantastic layout - really captures the atmosphere of the Irish countryside!
Would you model in 21mm if RTR track and models were readily available?
Fiacra replied to BosKonay's topic in Irish Models
Wow, looks great! This is making me seriously consider 21mm for a future layout. -
Jaysus, this is mind-blowing news! No more hunting on eBay for tippex mk2ds or, indeed, mk3s! I had long given up on ever finding a tippex mk2d EGV.
Lots of interesting and informative responses - fascinating stuff!
Perhaps, but I'm guessing they would also have been more expensive once delivery costs were factored in. And, this being Ireland we're talking about, finances would surely have been limited. A number of small and large diesels that BR introduced in the 60's went on to live long, productive lives on their network, so it's not as if they were incapable of producing reliable locos. Or, perhaps I'm wrong about the costs - maybe the GM locos worked out less expensive, even with the delivery costs?
