Horsetan
Everything posted by Horsetan
  1. Also, the part of the film which shows the train exiting from the viaduct pans back to show it approaching a "Y" point....
  2. He reminds me of Robert Opron.
  3. I'm after having a look at the inside of the Heljan Hymek bogie gear casing. It looks like there might be room to run a central axle through. Only just, but, and I suspect it could encroach on the gear mesh. Needs more thinking.
  4. I think you are correct on that one. The interlaced track was removed, apparently over a decade ago.
  5. That could work as a club layout....
  6. I think it really depends on what you think your requirements are - a scenario would be to design and build one bogie with secondary, and the other without, and then test them to see whether the secondary makes any difference. I would prefer to have secondary in 21mm gauge. Penbits' system would work with Murphy Models CIE diesels since the design is effectively a cradle that wraps over the existing power bogie, and the rest of the drivetrain is generally unaffected. Penbits don't do anything specific for CIE, and certainly not the Sulzer, which - being A1A+A1A - would be unlike anything they have produced before. That's why I have been looking at the Hymek bogie kit, which is the correct total wheelbase of 10'6, and wondering whether it might be modified to allow a central unpowered axle. The only other alternative RTR 10'6" bogie is the Bachmann Warship. Both Heljan and Bachmann I have found to be mostly unhelpful in answering specific spares queries, mainly because I think they don't really want to help. My preferred motor is invariably a big coreless one - something by Maxon or Faulhaber / Escap, which are fairly easily bought via eBay; do a search for a US-based seller called "microlocomotion", because he seems to deal in just about every size there is. Gears, I don't know. I'd prefer not to have to use worms; I like low-resistance bevels and spurs, or contrate-and-pinion. You can buy the latter from Ultrascale, but their order waiting list is notoriously long, usually six months. RP25-88 is not finer than P4; flanges are thicker, and the tyre overall width is wider at 2.2mm or more. P4 is usually in the range 1.85 to 2mm wide. A Sulzer 101 wheel is supposed to be 37" or 37.5" - 3ft 1in or 3ft 1.5in, depending on whose information you believe! AGW produces disc wheels It sounds like you've got a far better-equipped workshop than the vast majority of us! Do have a look and see if you can turn out a set of miniature bevel gears or contrate-and-pinion.
  7. Yes, I've seen some photos in "Rails To The West" - it must have made Claremorris as busy as stations in Dub.
  8. Grand!! Do let us see your drawings. I have a feeling that some of us might want to have a go at Claremorris - or parts of it - ourselves in future
  9. ...and they work. I picked up a kit to do the Prototype Deltic, and another for the Hymek. The prospect of Irish diesel sprung bogie kits is surely tempting.
  10. That would be a shunting challenge without equal.
  11. I'm sure they'll be worth it - and everyone will wonder why they hadn't thought of it before. I was looking at Penbits, which makes P4-compatible sprung suspensions for diesel bogies. Next time I see them at a show (probably next April/May), I'll ask if they'd consider Irish diesels, especially for 21mm gauge.
  12. It certainly was before the track layout was rationalised and everything went CTC in recent years. There must be some sort of building plans for Claremorris in existence in an archive somewhere, otherwise it's going to have to be a case of asking IE/IR's permission to measure up the various structures....
  13. I take it you've given up on doing Limerick Junction, then.
  14. In other words, "Limerick Junction is the maddest thing we've yet seen." Even the partial diagrams in this thread are like spaghetti.
  15. I had a go at the second one, but forgot about it.
  16. :banana:
  17. He'll build one for ye. All he needs is the info from ye.....and some money. Kerrygold.
  18. A brand-new Dacia will cost ye less than a 4mm scale engine built by Stella Artois.
  19. Here's his details: Rod Cooper, The Halt, Roshven, Lochailort, Invernesshire PH38 4NB Tel +44 1687 470284
  20. Tempted?
  21. If you can afford Rocar coaches, you can also afford to commission "Stella Artois" to build your engines. Prices start at a few grand. Something like a GSR "800" 4-6-0 would most likely cost five figures, with the decimal point after....
  22. Loads. At least 400 quid a coach. But yer man puts everything into it - working gangways, curtains, carpeting.....the works.
  23. Unfortunately, you need the boxes for things like that. Coaches like that are so expensive, you'd be afraid to run them....and certainly not at a show where you'd be paranoid they'd get stolen. Mind, though, Golden Age coaches are cheap (and not very well-detailed) compared to the ones made by this fella
